Results 1 to 9 of 9
Thread: Timing chain routing??
    [NortHStaR]'s Avatar
    [NortHStaR] is offline Cadillac Owners Fanatic
    Automobile(s): 1999 Cadillac DeVille
    Aug 2008
    Phoenix, AZ
    25
    279
    Getting ready to set timing and put the motor back in my car () but I need a diagram for the timing chain setup..
    Anyone have one?.. 1999 Cadillac DeVille Base, VIN Y.
    Thanks in advanced....
    97EldoCoupe's Avatar
    97EldoCoupe is offline Owner of Northstar Performance
    Automobile(s): 97 ETC x2, 04 GXP, 04 STS x2, 97 ESC, 99 Deville, 05 SRX
    Mar 2007
    The Great White North
    31
    2,600
    Re: Timing chain routing??
    Hey Chacen check this out- AJ has a great reference for this on the Fiero Forums:
    http://www.fiero.nl/forum/Forum2/HTML/080614.html
    jeffrsmith is offline Cadillac Owners Fanatic
    Automobile(s): '99 SLS, '05 Deville, '87 Porsche 944
    Dec 2007
    Ledyard, CT
    57
    299
  5. #4
    Aug 2008
    Phoenix, AZ
    25
    279
    Thank you both that was exactly what I needed!
  6. #5
    Mar 2007
    31
    2,600
    No problem!
  7. #6
    Apr 2014
    37
    1
    Hello everyone i have a problem I'm working on a 02 STS with north star engine , i took my heads to a machine shop and they took off the cam sprockets i dont remember how the went on, can anyone tell me how to set the sprockets so when i set the timing chain its correct
  8. #7
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    In the future, feel free to start your own thread, instead of tacking it onto a 5+ year old, semi related one.
    Can't they only go on one way? IIRC, each sprocket has 2 holes/slots for the pin in the cam to go through. 2 sprockets say RI and RE, and the other 2 say LE and LI.
    L = left
    R = right
    I = intake
    E = exhaust.
    You put the pin through either the I or E hole depending on which can you're installing it on.
  9. #8
    69
    82,262
    I'm confused. Why post the question in the first place in a thread that already has the answer?
  10. #9
    Submariner409's Avatar
    Submariner409 is online now If it won't run, chrome it
    Feb 2006
    MD Eastern Shore, Kent Island
    56,808
    joser, You might want to look at Post #3. There are three (3) timing chains and it takes cam locks to get everything in alignment with Cylinder 1 at TDC so you can install the sprockets, retract the 3 tensioners, set the chains, and unlock the tensioners. Did you replace the tensioner shoes and the chain guide slippers ? Oil everything.
    or, http://lmgtfy.com/?q=cadillac+forums...eplacement&l=1
  • You may not post replies
