Go Back   Cadillac Owners Group > General Discussion > Cadillac Engine Technical Discussion > Northstar Performance and Technical Discussion
Northstar Performance and Technical Discussion Performance discussions relating to the Northstar System (intake, exhaust, cam, etc.).
Cadillac Forums: 98 sts stalling..aj..ranger...sub...help
Old 08-27-08, 12:08 AM
Cadillac(s): Cadillac
View mikelawson's Photo Album
Casino Cash: $2110
Ok, I've tried it all,.... First I replaced the CKP's since it only stalls coasting to a stop or stopped. I have read multiple old threads and tried all things that I didn't think would cause it, and I'm still having the problem. To be more specific, it stalls with the engine hot or cold and only when coasting to a stop or stopped. It will do it 2 to 3 times a day in heavy traffic. I just replaced the head gaskets on this car and all is great except for this. The ONLY code is P1599 (engine near stall or stall) which makes this even harder since I don't have anything else to go on. Here's what I have tried,.... different EGR, different TPS, different cam position sensor, different IAC,...... I think that's all.. I've read about possible FPR, but I don't think so since it starts right up and never surges,...... I am going to try another set of coils, but once again, it never misses during cruising or acceleration. The backfire valve????? Never seen a bad one, but I guess I may try that as well. It definately doesn't have any vaccuum leaks either since it idles perfect when it doesn't stall. I didn't do a relearn on the ckps since everyone said it wasn't necessary, but should I give that a try??
  #2 (permalink)
Old 08-27-08, 01:30 AM
Cadillac(s): Member of Air Fuel Tuning (Cadillac Division)
View AJxtcman's Photo Album
Casino Cash: $13342
Re: 98 sts stalling..aj..ranger...sub...help
FPR can cause that.
The Back Fire valve can cause it also.
Were the Intake gaskets reused?
The intake gasket can cause this also.
Can you read the MAF values?
I would think that you should see above 6.73 g/s at idle. If you see less than that you may have a vacuum
  #3 (permalink)
Old 08-27-08, 12:15 PM
View Ranger's Photo Album
Casino Cash: $24266
For a moment I though maybe the TCC was not disengaging, but that would set a DTC. It has to be something that won't set one like the things AJ mentioned. While I would not expect those to cause a stall, he is more knowledgeable about it than I.
  #4 (permalink)
Old 08-28-08, 04:36 PM
Casino Cash: $2110
I replaced the map sensor and the set of coils and all is better now. Not sure which one actually fixed it, but all is better now. Thanks for the input.
Mike
Tags: , , , ,
stallingajrangersubhelp, sts
