Go Back   Cadillac Owners Group > General Discussion > Cadillac Engine Technical Discussion > Northstar Performance and Technical Discussion
Northstar Performance and Technical Discussion Performance discussions relating to the Northstar System (intake, exhaust, cam, etc.).
Cadillac Forums: loss of power overheating issues HELP
  #16 (permalink)
Old 05-12-09, 10:39 PM
lathe2nd's Avatar
Cadillac(s): '97 ETC '94 SLS
View lathe2nd's Photo Album
Casino Cash: $385
Re: loss of power overheating issues HELP
ok, new fuel filter, new plugs... only code it's pulling is the 0300 for engine misfire. it is running smooth at idle revs up a little better to 2300 rpm them bogs down if i push it beyond 2300rpm it will stall. tomorrow i am going to test the cat for being plugged by removing the o2 sensor and running it a little with the purpose mage exhaust leak and see if it runs better... if not anyone looking for parts? i've also got a 94 sls as well.
  #17 (permalink)
Old 05-12-09, 11:17 PM
View Ranger's Photo Album
Casino Cash: $24166
I'm not sure if that will work. You could remove the O2 sensor and install an exhaust back pressure gauge or disconnect the exhaust prior to the CAT and see it if runs any better.
  #18 (permalink)
Old 09-26-09, 12:10 AM
lathe2nd's Avatar
Casino Cash: $385
Hi guys! Great news... it's been a busy summer but I finally had time to work on the caddy...
I disconnected the cat and tried to run it with open exhaust to see if it would run any better - turned out that what it was!
Fortunately I live in western PA where we don't have emissions testing, so I took the cat out used a pipe to smash out the honeycomb - with a new gasket, bolts, 2 clamps and a coupler from advance, I'm back on the road for $12.00
Even better 28 - 29 mpg on the highway if I drive the speed limit on level road... but thats not easy to do in an ETC, lol
Thanks to all of you for your suggestions.
Tags: , ,
issues, loss, overheating, power
