Originally Posted by SuperC You guys were right, the part that I bought did go on the 2000 N*! I took the part anyway and used it to cap off the nipple that was covered by the broken piece. New gaskets and coil and she runs like a champion!!! No hesitation, no SES no rough idle!!!!!!
FYI: I had two mechanics look at the part that was broken in a deville that was in the dealership and neither knew what it was or what it did.
I am not to sure how to test the coil. I did read the resistance between coils and got 10.5k ohms on both the new and the old coil. I am going to put the old one back in, just to see if it is the issue. If I can return it to Advance, it saves me $175.
Thank you guys again!!! I could have never done this without ya'll. This is SUCH a great resource.
Thanks,
-C |
Hi,
I have the same problem with my 2000 cadillac sts as you had, but I'm confused about part 567. I have the factory service manual, and in the manual it just shows a rubber cap on the intake manifold where part 567 goes. In your post you said that you didn't need it but used the part to cap off the nipple. Am I correct about this?
Additionally I cant find the plenum on rock auto -- I'm not sure if i need it, but can you buy one from them? I havn't taken the car apart yet, but can the plenum be replaced without taking the intake manifold off? I dont want to buy a second set of seals after the fact.
If you could please let me know, It would really help me out. Thank you,
Andrew Webb
