Go Back   Cadillac Owners Group > Cadillac Engine Technical Discussion > Northstar Performance and Technical Discussion
Northstar Performance and Technical Discussion Performance discussions relating to the Northstar System (intake, exhaust, cam, etc.).
Cadillac Forums: 98 Deville non-functional engine cooler fan
Old 07-05-08, 01:37 PM
nickpitlosh nickpitlosh is offline
Cadillac(s): Cadillac
View nickpitlosh's Photo Album
Casino Cash: $480
Hello guys,
I have a 98 deville that I have been looking at, for a while now I noticed that the temperature on the IPC says that the coolant gets pretty hot, well over 200 degrees. Not good. Poking around for a problem shows me that the cooling fans on the back of the radiator never turn on! Yikes, can someone give me some diagnostic instructions? The Alldatadiy site seems less than informative about exactly how the fans operate. Thanks in advance, someone here almost always points me in the right direction.
  #2 (permalink)
Old 07-05-08, 02:41 PM
submariner409's Avatar
submariner409 submariner409 is offline
Cadillac(s): 2002 Cadillac F55 STS/51000mi., 2004 Ford F150 Super cab 4x4
Casino Cash: $16874
Re: 98 Deville non-functional engine cooler fan
One or both cooling fans come on low speed at 224 degrees, high at 236. One fan will run slow in any mode that calls for the a/c compressor to run.
The engine is designed to run at 206-220 degrees: the thermostat starts at 188 and is fully open at 206, so the oil (if you have a radiator end tank "oil cooler") and coolant will always be at or above 200...always. 18 psi cap, 50/50 DEXCOOL is a boil point of 264.
You could double check the fan fuses in the engine room box.....2 fuses and maybe 2 relays, although the relays on a 98 may be down on the fan bracket. (....and it can take a long time for a fan to come on at idle.)
  #3 (permalink)
Old 07-05-08, 04:31 PM
Ranger Ranger is online now
View Ranger's Photo Album
Casino Cash: $20546
To summarize what Sub said, you ain't got no problem. Sounds like it is operating as designed. 200 degrees is FAR from hot.
  #4 (permalink)
Old 07-05-08, 05:30 PM
Casino Cash: $480
Thanks Guys!
Tags: , ,
cooler, deville, engine, fan, nonfunctional
detail pro cadillac whitewall wipes
cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods | air suspension kits | air suspension parts | air ride suspension | hyundai genesis forum | Sirius Radio
