Go Back   Cadillac Owners Group > General Discussion > Cadillac Engine Technical Discussion > Northstar Performance and Technical Discussion
Northstar Performance and Technical Discussion Performance discussions relating to the Northstar System (intake, exhaust, cam, etc.).
Cadillac Forums: 300hp N* to a Base N*
Old 07-04-08, 11:37 AM
1990CaddyBrougham's Avatar
Cadillac Nut Bag
Cadillac(s): 00 DTS, 90 Brougham, 81 X3 Black FWBC Delegance, 96 FWB
View 1990CaddyBrougham's Photo Album
Casino Cash: $5216
WIll a base northstar work in a DTS with the HO northstar?
I found a pretty good deal on another 00 DTS, needs a motor, and also a good deal on a motor, but its from a base 05
  #2 (permalink)
Old 07-04-08, 11:58 AM
CadillacSTS2003's Avatar
Zeeee-yaaaa
Cadillac(s): 07 STS 1SG, 03 STS, 74 Eldo, 98 Z28, PAST: 97 ETC
View CadillacSTS2003's Photo Album
Casino Cash: $12230
Re: 300hp N* to a Base N*
Will it bolt in
yea
will you have some other issues like it not running properly due to the variance in cams
yea
if you get the DTS and put the base motor in with the DTS heads then youll be just fine but keep in mine then you pretty much doing headgaket repair
  #3 (permalink)
Old 07-04-08, 03:02 PM
C&C's Avatar
C&C C&C is offline
Cadillac Owners Enthusiast
Cadillac(s): Cadillac STS (2006)
View C&C's Photo Album
Casino Cash: $14190
"Sub" you out there; what say you. I'm thinking it should be fine (but I yield to the more experienced).
  #4 (permalink)
Old 07-04-08, 03:03 PM
Zeeee-yaaaa
Casino Cash: $12230
ouch
i believe thats a burn on me....
  #5 (permalink)
Old 07-04-08, 03:45 PM
submariner409's Avatar
Casino Cash: $20694
C&C, STS2003 has a couple of good points, and quite frankly I have no experience swapping a 2000 4.6 with a 2005. From reading CF threads concerning different years/models, the install you're contemplating could be done, but there will be some mechanical and electrical/electronic hoops to jump through. There were camshaft and engine controls changes over those 5 years. It doesn't appear to be a bolt-in, and may present some problems to be worked out. My .02 . (Best bet? Go to a closer year motor/transmission, if possible.....01 or 02.)
  #6 (permalink)
Old 07-04-08, 04:05 PM
Cadillac(s): Member of Air Fuel Tuning (Cadillac Division)
View AJxtcman's Photo Album
Casino Cash: $13342
The VIN Y (275hp) will make More Power than the VIn 9 300hp oh I mean the 292hp will in that car. I would look for a 2002 to 2005 VIN Y engine
  #7 (permalink)
Old 07-04-08, 04:20 PM
Zeeee-yaaaa
Casino Cash: $12230
more power down low you mean AJ
  #8 (permalink)
Old 07-04-08, 04:27 PM
Casino Cash: $13342
YES anything below 5100 rpm's, but you run your car over 5100 constantly correct. You never drop below 5100.
  #9 (permalink)
Old 07-04-08, 04:29 PM
Cadillac(s): 98 sls
View Crown Vic Owner's Photo Album
Casino Cash: $5564
These cars definitely need the lowend.
Would it be possible to swap over the new PCM and harness or is that a total fockin nightmare?
  #10 (permalink)
Old 07-04-08, 07:13 PM
Zeeee-yaaaa
Casino Cash: $12230
AJ
lets just say theres a reason why my STS gets at BEST 14 mpg
and CV
no that would make matters even worse the new pcm wouldnt be ready to accept the 3.71 gears and would throw a constant CEL lamp
  #11 (permalink)
Old 07-04-08, 07:45 PM
Cadillac(s): 98 sls
Casino Cash: $5564
Would it fock up the shift scheduling or is that done via RPM on these motors? WHY would it throw a CEL? Could a idiot with a tech 2 or similar change the RAR setting if there is one?
  #12 (permalink)
Old 07-04-08, 08:35 PM
Casino Cash: $13342
It is just a cam swap.
  #13 (permalink)
Old 07-04-08, 09:16 PM
View Ranger's Photo Album
Casino Cash: $24241
What about the mismatched final drive?
  #14 (permalink)
Old 07-04-08, 10:51 PM
Casino Cash: $13342
I was thinking he had an STS not an SLS.
300hp, base
