Page 2 of 2 FirstFirst 12
Results 16 to 26 of 26
Thread: Nitrous Wet Or Dry???
  1. #16
    Mar 2004
    1,063
    Re: Nitrous Wet Or Dry???
    Quote Originally Posted by GONEB4U
    Sorry, Dude, I just don't think there is that much r&d with N20 on these cars!
  2. #17
    Nov 2003
    Independence, MO
    19
    GONEB4U -
    Did you ever try this?
    I'm looking for help for my 98 Aurora... shy of swapping a 4.6l into it... which would be a waste of a perfectly good 4.0 (besides, I've yet to see if anyone has performed a 4.6L Aurora swap yet).
  3. #18
    danbuc's Avatar
    danbuc is offline Cadillac Owners Connoisseur
    Automobile(s): '87 Jeep, '10 Thruxton, '00 Duc 748, '01 748R (853cc)
    Mar 2004
    Mahwah, NJ
    32
    3,703
    I found this over on the cadillacowners site. This person has a '98 STS, but they installed a dry system on it.
    edited by Sal Collaziano: We do not associate with this site as the owner has spammed our members and has a long list of enemies online for bad etiquette. If you want to send somebody a link, send it to them via email.
  4. #19
    Nov 2003
    Independence, MO
    19
    danbuc,
    can you guide me in another way?... that link didn't work on my machine
  5. #20
    Jan 2003
    Newtown, PA
    58
    6,472
    Up to 100 shot (dry) should be fine. The O2 sensors don't really make much difference in this case since the nitrous is only flowing at WOT. Once at that throttle angle, the injectors are basically just dumping based on the WOT table in the PCM.
    I've been considering the same question myself recently and have pretty much decided on the 100hp dry system too mainly due to cost and ease of installation. If you were going for more power, I'd suggest a wet system and several other upgrades to support it. Replacing your EOM feul pump might be a good idea too. The last thing you want is to have the pump go lean on you during a nitrous run.
  6. #21
    Feb 2004
    FL
    2,250
    Quote Originally Posted by Katshot
    I'm going to disagree. The maximum I would be comfortable with is probably 50. Here's why:
    With a dry system, you need to up the fuel pressure so that your injectors flow more for the new given oxygen. For 100 extra hp, you would need to turn your stock 19lb injectors (I think that's right, correct me if I'm wrong) into 25lb injectors. Given a stock pressure of ~45psi, you would need to crank it up to 85psi. IMO, that's unreasonable. Number one, I highly doubt the fuel pump would still be able to flow at the pressure, and number two, your injectors may not even be able to OPEN at those pressures.
    as a side note, 350hp would require ~65psi, which is probably the ragged edge of where the system still works. I wouldn't use a dry system myself however, it's a lot more risky, and very prone to detonation if timing isn't retarded. (Something you can't do without an aftermarket ECM)
  7. #22
    xdamxincx is offline Cadillac Owners Member
    Automobile(s): 07 Cadillac cts
    Apr 2007
    wpb fl
    16
    Quote Originally Posted by eldorado1 View Post
    and i highly disagree with your statements ... pretty much any fuel injected car will handle a 100 dry shot of nitrous. fuel injectors work in duty cycles and the computer can sense the added air intake by the presence of vacuum and that will make the injectors cycle more to provide more fuel and enough for a 100 shot of nitrous .. and same goes for timing u wont need much timing pulled for a 100 shot this will be done by knock sensors.. .... i will be doing it to mine here soon. just make sure that you guys use premium octane fuel
    and this is based off of putting the nozzle after the mass air sensor.. if u put it downstream of the mass air .. it will measure air density and temperature and do all the same changes...
  8. #23
    69
    82,273
    Do you realize that this thread is 5 years old? Most of these guys have not even posted in over a year.
  9. #24
    cl1986's Avatar
    cl1986 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 Eldorado, 94 SLS got crushed
    Jun 2003
    South Dakota
    38
    1,485
    well wheres all the blown up N* at???
  10. #25
    Apr 2007
    wpb fl
    16
    lol yea i know .. im just bored
  11. #26
    AJxtcman's Avatar
    AJxtcman is offline Cadillac Owners Connoisseur
    Automobile(s): The Northstar Tuner
    Apr 2007
    Rock Hill SC
    48
    2,755
    We ran 250 shot for a long time and even went way up to something like a 400 shot for a full day at the track. The engine hasn't been apart since we added the N2O
    http://www.cadillacforums.com/forums...ect-way-i.html
  • You may not post replies
