| Northstar Performance and Technical Discussion Performance discussions relating to the Northstar System (intake, exhaust, cam, etc.). | Cadillac Forums: replaced hg, low oil pressure
04-13-08, 10:12 PM
|  | Cadillac Owners Fanatic Cadillac(s): Cadillac | | | | | replaced hg, low oil pressure I just replace the headgaskets on my 98 STS and now the oil light it on, the DIC says low oil pressure, stop engine. you can hear the lifters make noise to, its not getting presure.
Any ideas,
Oh yea, I put 16 quarts of oil in the engine and ran it for a min and that did not work. |
04-13-08, 10:42 PM
| | Cadillac Owners Connoisseur Cadillac(s): 94 ETC,97 STS | | Join Date: Sep 2003 Location: Arizona | | | Re: replaced hg, low oil pressure When we let the engine sit for about two months we got a lot of lifter clatter for a long time. Limited flow to the lifters so it takes awhile to refill them.
We didn't have a pressure problem. Did you overfill to try to prime the pump?
Is the harmonic balancer on tight enough? I think it calls for 250 ft/lb. It drives the oil pump. |
04-13-08, 11:53 PM
| | Cadillac Owners Connoisseur Cadillac(s): 98 Seville SLS *Lord Vadar* | | Join Date: Mar 2005 Location: DFW Texas Age: 23 | | | Re: replaced hg, low oil pressure Yeah, make SURE that the harmonic balancer bolt is torqued. It drives the oil pump and might be causing this issue. |
04-14-08, 06:15 PM
| | Cadillac Owners Fanatic Cadillac(s): 2005 XLR, '96 eldo,'95 eldo,' 89 eldo,'78 eldo,'97 seville | | Join Date: Dec 2004 Location: perryman, MD Age: 65 | | | Re: replaced hg, low oil pressure If I recall, there's no keyway for the HB and the oil pump; just a tight fit. Shaky design, if you ask me... |
04-14-08, 06:34 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 1997 ETC, 2000 DTS | | Join Date: Jul 2007 Location: FOUNTAIN HILLS, AZ Age: 53 | | | Re: replaced hg, low oil pressure Joe - I e-mailed you earlier - I just got your e-mail today. Anyway, AJ is correct, of course
Richard Moore |
04-14-08, 06:42 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 1997 ETC, 2000 DTS | | Join Date: Jul 2007 Location: FOUNTAIN HILLS, AZ Age: 53 | | | Re: replaced hg, low oil pressure Oops - I e-mailed you about the brace.
Low oil pressure - yeah - what JC316 said. I also had noisy lifters for a few minutes after I first started the engine, but no low oil pressure warning, so I think you do have a problem. You torque the balance bolt to 37 ft lbs and then 120 degrees - one 1/3rd turn - one spoke.
Does that help? |
04-17-08, 10:52 PM
|  | Cadillac Owners Fanatic Cadillac(s): Cadillac | | | | | Re: replaced hg, low oil pressure Richard, after reading up on this the problem was the balance bolt I am good now, thanks |
04-21-08, 09:33 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 1997 ETC, 2000 DTS | | Join Date: Jul 2007 Location: FOUNTAIN HILLS, AZ Age: 53 | | | Re: replaced hg, low oil pressure So the job was an unqualified success Joe? |
04-24-08, 06:41 AM
|  | Cadillac Owners Fanatic Cadillac(s): Cadillac | | | | | Re: replaced hg, low oil pressure well yes and no, I got the oil pressure working, had an issue with the fuel pump ended up being a loose ground wire.
Now I have an ABS Issue, Ok, I took the car for a ride and the ABS and traction controll came one, the car ran like crap, when I go over 2K RPM's the guages go nuts and the car stals, I turned around and drove it home and kept it under 2K and it was fine,
Also when I start the car the the abs and traction control light do not go on until I get going down the road.
I dont trust my local Cadillac Dealer, they are know to fix things that are not broke and charge people, so I called a local mechanic that used to work for that dealer and he seems to think somthing is not conected or grouned. |
04-24-08, 09:49 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 1997 ETC, 2000 DTS | | Join Date: Jul 2007 Location: FOUNTAIN HILLS, AZ Age: 53 | | | Re: replaced hg, low oil pressure yES - A BAD CONNECTION OR gROUND |
04-24-08, 10:37 PM
|  | Cadillac Owners Fanatic Cadillac(s): Cadillac | | | | | Re: replaced hg, low oil pressure yea, finding it is the hard part |
04-25-08, 03:35 AM
|  | Cadillac Owners Fanatic Cadillac(s): 2004 Deville; 1999 Seville | | | | | Re: replaced hg, low oil pressure Quote:
Originally Posted by zonie77 When we let the engine sit for about two months we got a lot of lifter clatter for a long time. Limited flow to the lifters so it takes awhile to refill them.
Is the harmonic balancer on tight enough? I think it calls for 250 ft/lb. It drives the oil pump. | is 250 ft/lb the same as 37lb + 120 degree turn? |
04-25-08, 11:59 AM
|  | Cadillac Owners Connoisseur Cadillac(s): 1997 ETC, 2000 DTS | | Join Date: Jul 2007 Location: FOUNTAIN HILLS, AZ Age: 53 | | | Re: replaced hg, low oil pressure I don't think so. It was REALLY REALLY HARD to break loose, but it was easy to tighten when installing. So easy in fact, I re-loosened the bolt and followed the procedure again, but I had done it correctly the first time. I didn't measure the torque, obviously, but it did not seem much over 100 ft lbs, if I had to guess. I think the cam bolts are 90 and it seemed a bit tighter than that. Maybe I just don't know my own strength? |
04-25-08, 08:49 PM
|  | Cadillac Owners Fanatic Cadillac(s): Cadillac | | | | | Re: replaced hg, low oil pressure well I had a bad morning, Driving home and the car started acting like it was out of gas and then died, I figured out the fuel pump is not coming on, I think its a ground issue.
Any ideas |
04-26-08, 12:19 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 1997 ETC, 2000 DTS | | Join Date: Jul 2007 Location: FOUNTAIN HILLS, AZ Age: 53 | | | Re: replaced hg, low oil pressure Geez, Joe - that's too bad you are having these problems. I was afraid I was going to have a lot of these kind of problems, because of all the wires that were disconnected and or unplugged. Remember, I disconnected even more than you, because I took the block out of the cradle to change the oilpan gasket and rear main seal. I think you just did the HGs, right? Anyway, my car has gone well over 1,000 miles and has been trouble free so far; no suggestions, but good luck to you. | | Cadillac Discussion Tools | | |
Censor is ON | | | |
