| Northstar Performance and Technical Discussion Performance discussions relating to the Northstar System (intake, exhaust, cam, etc.). | Cadillac Forums: Is this a cracked intake plenum? (see attached pics)
04-12-08, 08:47 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | Is this a cracked intake plenum? (see attached pics) |
04-12-08, 09:24 PM
| | Cadillac Owners Connoisseur Cadillac(s): Member of Air Fuel Tuning (Cadillac Division) | | Join Date: Apr 2007 Location: Inside The Northstar PCM Age: 41 | | | Re: Is this a cracked intake plenum? (see attached pics) YES
I am glad to see the pictures  |
04-12-08, 09:39 PM
|  | If it won't run, chrome it..... Cadillac(s): 2002 Cadillac F55 STS/53000mi., 2004 Ford F150 Super cab 4x4 | | Join Date: Feb 2006 Location: Maryland upper Eastern Shore Age: 69 | | | Re: Is this a cracked intake plenum? (see attached pics) Order the plenum and a set of (new, upgraded) intake manifold gaskets.
Many, many posts in here over the past several months, with pictures and commentary, on how to do the job. An easy afternoon's work. |
04-12-08, 10:31 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | Re: Is this a cracked intake plenum? (see attached pics) Thank you for your help, on this thread and on others! I will research, order parts, and fix this!
Is this a good time to do some other maintenance? I was thinking I could also clean the TB and possibly inspect the EGR valve and maybe the MAF sensor at the same time. What do you think? Is there anything else I should check out while I'm working under the hood? My car has 115,000 miles and I changed the plugs and plug boots about 500 miles ago. Aside from oil changes, air filter, tires, and battery, nothing else has been changed or worked on.
Thank you again! You folks, and this whole forum, are the best!  |
04-14-08, 01:40 AM
|  | Cadillac Owners Enthusiast | | Join Date: Feb 2003 Location: Nashville | | Re: Is this a cracked intake plenum? (see attached pics) Yes, pretty good catch picture wise.
Typically the crack is on the bottom. Dont know why..maybe the nasty goo's from PCV / EGR valves have a place to hid.
Yes, the intake has to come off to replace this $25 rubber coupler. Good news is in most cases you can reuse the intake gasket.
It's a dry intake, couple hour job. No coolant issues. Pretty fast job.
BTW..getting any codes? Lean banks?
Logan Diagnostic LLC www.ledfix.com www.airbagcrash.com http://www.logandieselusa.com/deutzdiesels.html |
04-14-08, 09:24 PM
| | Cadillac Owners Fanatic Cadillac(s): Cadillac | | | | | Re: Is this a cracked intake plenum? (see attached pics) SmoothTS,
I'm having a slightly rough idle issue too. Mine feels like a very slight miss. Could you please describe your rough idle. How were your Ltrims at idle? |
09-05-08, 09:25 PM
| | Cadillac Owners Member Cadillac(s): 2003 Cadillac STS, 1994 Cadillac SLS | | Join Date: Sep 2008 Age: 40 | | | Re: Is this a cracked intake plenum? (see attached pics) Can you re post the plenum pics. They are not showing up on my screen? |
09-05-08, 09:39 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: Is this a cracked intake plenum? (see attached pics) I don't see any either. |
09-05-08, 10:59 PM
|  | If it won't run, chrome it..... Cadillac(s): 2002 Cadillac F55 STS/53000mi., 2004 Ford F150 Super cab 4x4 | | Join Date: Feb 2006 Location: Maryland upper Eastern Shore Age: 69 | | | Re: Is this a cracked intake plenum? (see attached pics) ...........doubt he will bump a 5 month old thread that has been fixed......The pics showed a typical 2000+ cracked plenum at the bottom of the bellows and at the s/s ring clamp.
Many, many more such pics here, in Seville and Deville. |
09-05-08, 11:48 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: Is this a cracked intake plenum? (see attached pics) Sub, why do you see the pics and we can't? |
09-06-08, 12:00 PM
|  | If it won't run, chrome it..... Cadillac(s): 2002 Cadillac F55 STS/53000mi., 2004 Ford F150 Super cab 4x4 | | Join Date: Feb 2006 Location: Maryland upper Eastern Shore Age: 69 | | | Re: Is this a cracked intake plenum? (see attached pics) I did not see the pictures this time around: I remember replying to his question and looked for my post in which I HAD seen the pictures......but I have not seen hide nor hair of the OP since then.............
Logandiagnostic also seems to have seen the pics referred to in the first post.
As far as MillerBlack's question, a dental mirror or small mechanic's mirror and flashlight will sometimes show the crack(s) if you look at the bottom of the plenum bellows. The edges of the crack may be shiny and oily.
The pics below were taken from a post last year concerning a 2001 DHS plenum. Click and scroll in....... | | Cadillac Discussion Tools | | |
Censor is ON | | | |
