  Follow CadillacOwners on Twitter
Go Back   Cadillac Owners Group > General Discussion > Cadillac Engine Technical Discussion > Northstar Performance and Technical Discussion
Northstar Performance and Technical Discussion Performance discussions relating to the Northstar System (intake, exhaust, cam, etc.).
Cadillac Forums: 01 Dts Rough Idle
Old 03-10-08, 09:09 AM
Cadillac(s): NONE
View pontiacsouth's Photo Album
Casino Cash: $1325
01 Dts Rough Idle
My DTS has started to have a rough idle last week. Feels like it has a beefy cam in it when its idling since it sort of rocks the car. I can also feel it chugging a little under acceleration. What would be the cause of this? I have some plugs i am going to throw in this weekend, since i dont know if the previous owner ever changed them. The mileage is 128k. Is there anything else i can replace to get my smooth idle again? let me know what u think. thanks
  #2 (permalink)
Old 03-10-08, 09:26 AM
submariner409's Avatar
Cadillac(s): 2002 Cadillac F55 STS/53500mi., 2004 Ford F150 Super cab 4x4
Casino Cash: $3624
Re: 01 Dts Rough Idle
What kind of plugs are "some plugs"? Northstars like ACDelco, period, and I believe your engine takes #41-987, $4.90 in packs of 8 from www.rockauto.com. You'll probably find a couple of tracked or torn coil connector boots, so replace them also. (The Packard/Delphi p/n.) Make sure the ground spring in the coil cassettes is "springy". Removing the A.I.R. valve on the back cassette can be a bit hairy.
  #3 (permalink)
Old 03-10-08, 09:41 AM
Cadillac(s): NONE
Casino Cash: $1325
submariner409, i got delcos as i read the previous posts bashing all others. I am dreading doing the back plugs, will have to stock up on beer before tackling them. I will try to find a good set of boots also.
thanks for the reply...
  #4 (permalink)
Old 03-10-08, 10:06 AM
Casino Cash: $3624
The boot number, GM, is 12163650, $2.85 ea. at Rockauto, but a non-stock item. Try Gmotors in Gainesville (Brasington Cadillac), GMPartsDirect, or Flow Chevrolet/GM in Raleigh (?) NC.
  #5 (permalink)
Old 03-10-08, 08:57 PM
Cadillac(s): Cadillac
View VIPERRACING's Photo Album
Casino Cash: $735
Im having the same problem with my 99 sts with only 80,000 miles. Would the egr valve cause this problem also? How about bad intake gaskets? Thanks.
  #6 (permalink)
Old 03-10-08, 09:32 PM
View Ranger's Photo Album
Casino Cash: $28156
Bad intake gasket would likely cause a high idle and a P0171 or P0174 code. EGR sounds more likely, but it should set a code as well. Have you cleaned the TB?
  #7 (permalink)
Old 03-10-08, 09:37 PM
Casino Cash: $735
No codes and I have cleaned the throttle body and also have seafoamed the intake. Im thinking of putting a egr block off plate to see if that helps out. Are the same ranger that has the z06 ? Thanks for any help.
  #8 (permalink)
Old 03-10-08, 09:41 PM
Casino Cash: $28156
Nope, he's an impostor.
  #9 (permalink)
Old 03-12-08, 12:11 PM
Cadillac(s): NONE
Casino Cash: $1325
after checking the onbord codes i have a P0300, which is misfire detected...
  #10 (permalink)
Old 03-17-08, 07:38 AM
Cadillac(s): NONE
Casino Cash: $1325
i changed the plugs & boots this weekend. there is still a misfire code coming up. although the engine does seem to run smoother. i did clear the codes b.t.w.
i looked inside the throttle body. it was pretty black in there. i cleaned the butterfly off but how can i clean out the intake. i heard of seafoaming but how can i do it???
maybe one of the coils are bad or its just a dirty intake??
  #11 (permalink)
Old 03-17-08, 12:28 PM
Casino Cash: $3624
Do not remove and block the EGR system. The ignition will sense the resulting low speed/part throttle knock and default to limp-home retard timing, as well as set airflow and mixture codes.
Did you remove and clean/replace the plug connector boots? They sometimes carbon track and cause a misfire. How about the spring tension on the coil cassette ground springs ?
DO NOT shoot the intake full of magic potions. There's a thread here from last fall about someone who did just that and had a devil of a time stopping the smoke and banging that resulted.
Look for several threads here, and in Seville/Deville over the last 8 months, concerning intakes, throttlebodies, rubber plenums, and cleaning. (There's another, similar, thread right next to this one........)
I'll bet the misfire comes from either intake manifold gaskets, bolts, or a torn plenum.......has an oxygen sensor lean code (P017x) set ?
  #12 (permalink)
Old 03-17-08, 02:17 PM
Casino Cash: $28156
Just clean the TB bore, Throttle plate (backside & perimeter). Like Sub said, forget the manifold. That is normal crankcase gases and EGR gases that settle out when the engine is shut down. It does no harm and will only return in short order.
  #13 (permalink)
Old 03-17-08, 05:21 PM
Cadillac(s): NONE
Casino Cash: $1325
no, there are no other codes the the generic P0300 misfire.
i have different coils to put on someday also. a lot of people said that this have cured their missfires.
i'll just leave the intake dirty, just saw it was all carbon build up in there and thought i gotta clean it out.
thanks for your advise
  #14 (permalink)
Old 03-17-08, 10:59 PM
Casino Cash: $28156
A lean O2 sensor would point to a vacuum leak.
Tags: , ,
dts, idle, rough
attach your bluetooth cell phone to onstar
flash wax for your cadillac
cadillac key wraps
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
custom floor mats | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods | air suspension kits | air suspension parts | air ride suspension | hyundai genesis forum
