| Northstar Performance and Technical Discussion Performance discussions relating to the Northstar System (intake, exhaust, cam, etc.). | Cadillac Forums: Plz Listen 2 My story Need Help ASAP
03-03-08, 11:35 AM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Plz Listen 2 My story Need Help ASAP To Make It shirt....I ran out of gas, put gas back in, mad it back 2 my house but the car was running really slow like no gas was getting to it, came out the next morning and car wont turn over, sprayed a little started fluid and cleaned my throttle body.....now it starts with no problems until i put my car in drive, and step on the gas, then it shuts off, Wat Can Be The Problem??????? |
03-03-08, 11:41 AM
|  | Cadillac Owners Master Cadillac(s): 05 Redline CTS-V | | Join Date: Dec 2006 Location: In the barber's chair.... Age: 28 | | | Re: Plz Listen 2 My story Need Help ASAP clogged fuel filter.... |
03-03-08, 12:26 PM
| | Cadillac Owners Member Cadillac(s): 99STS | | Join Date: Mar 2008 Location: Florida | | | Re: Plz Listen 2 My story Need Help ASAP Sometimes if you run out of gas there is crud in the bottom of the tank and it goes through the system.. Hopefully all of this just got caught in your filter and all you have to do is get another one and pop it out with the quick connects and pop another one in.. Easy, just make sure you release the pressure on the system first through the little valve in the fuel rail or let the car sit for a while. |
03-03-08, 12:52 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: Plz Listen 2 My story Need Help ASAP The pump is cooled by the gas. Chances are that you burned up the pump by running it dry. Put a fuel pressure gauge on it and see what kind of fuel pressure you have, if any, but check the fuse first. |
03-05-08, 11:29 AM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: Plz Listen 2 My story Need Help ASAP Quote:
Originally Posted by RunningOnEMT clogged fuel filter.... | so when i get the new fuel filter and it still wont start would could be some other possibilities???????? |
03-07-08, 07:21 AM
| | N* Headgasket Survivor Cadillac(s): 99 Z-rated STS, 90 Coupe Deville (sold) | | Join Date: Apr 2007 Location: The Ocean State Age: 46 | | | Re: Plz Listen 2 My story Need Help ASAP Quote:
Originally Posted by yungwun724 so when i get the new fuel filter and it still wont start would could be some other possibilities???????? | Read Ranger's post - possibly a cooked fuel pump. |
03-08-08, 11:33 AM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Would Having a bad MAF sensor make a car not start????? ok so my throttle body blew out a flame b/c of all the combustion and then my MAF sensor got burnt....would this make a car not drive or start? |
03-08-08, 11:35 AM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: Plz Listen 2 My story Need Help ASAP ok so i put my fuel filter back in...and my car starts better then it did before but it still wont drive it just cuts off....i have no codes on my dash but i do have a bad MAF sensor.....and if i can hear my fuel pump iz that bad or good?????? |
03-08-08, 11:45 AM
|  | Zeeee-yaaaa Cadillac(s): 07 STS 1SG, 03 STS, 74 Eldo, 98 Z28, PAST: 97 ETC | | Join Date: Oct 2005 Location: Cheswick, PA Age: 23 | | | Re: Plz Listen 2 My story Need Help ASAP English mastery my friend...
and a bad maf can and will cause drive ability issues... |
03-08-08, 11:50 AM
|  | If it won't run, chrome it..... Cadillac(s): 2002 Cadillac F55 STS/53000mi., 2004 Ford F150 Super cab 4x4 | | Join Date: Feb 2006 Location: Maryland upper Eastern Shore Age: 69 | | | Re: Would Having a bad MAF sensor make a car not start????? From your other threads, did the backfire occur after spraying starting fluid or choke cleaner in the throttlebody ??
Yes, the Mass AirFlow sensor directly controls fuel trim, so if it is toast (the resistor bridges are fragile..) you may well have a no-start condition.
There are also several other sensors in and near the TB which control fuel and air mixture trim. Any one can now be toast. |
03-08-08, 11:52 AM
|  | Zeeee-yaaaa Cadillac(s): 07 STS 1SG, 03 STS, 74 Eldo, 98 Z28, PAST: 97 ETC | | Join Date: Oct 2005 Location: Cheswick, PA Age: 23 | | | Re: Would Having a bad MAF sensor make a car not start????? why create another thread for your problem?? |
03-08-08, 12:47 PM
|  | Cadillac Owners Master Cadillac(s): 1989 STS / 2001 DTS / 2002 DTS | | Join Date: Apr 2005 Location: Upstate NY | | | Re: Would Having a bad MAF sensor make a car not start????? That's one of the reason you're never supposed to use started fluid on a fuel injected engine. That crap is for carburetors.
__________________ Ownership:
89 STS (1 of 1893) - FOR SALE
02 Blue Onyx DTS 01 DTS: Custom installed Volant CAI Custom PCM Body color engine components Cruiser Alloy wheels EBC brakes Eibach springs
Corsa exhaust Sportwing Spoiler Semi-custom interior Custom quad Hi-Beams Future Plans: More interior work. Memberships: National and regional Cadillac & LaSalle Club Proud Volunteer - Northstar Tuning Project ---------------------------- |
03-08-08, 01:14 PM
| | N* Headgasket Survivor Cadillac(s): 99 Z-rated STS, 90 Coupe Deville (sold) | | Join Date: Apr 2007 Location: The Ocean State Age: 46 | | | Re: Plz Listen 2 My story Need Help ASAP If you can hear your fuel pump (1-3 second whirr under the back seat at key 'on') that is a good thing - it means you dodged a bullet. Change your MAF sensor. |
03-09-08, 11:46 PM
|  | Cadillac Owners Master Cadillac(s): 1989 STS / 2001 DTS / 2002 DTS | | Join Date: Apr 2005 Location: Upstate NY | | | Re: Plz Listen 2 My story Need Help ASAP Sorry about the typo up there, obviously I meant Starter Fluid. |
03-10-08, 11:22 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: Plz Listen 2 My story Need Help ASAP you need to check the fuel pressure. Im thinking you cooked your pump by running it low on gas. a cooked pump can give enough pressure to start but not drive. you need to check the pressure first | | Cadillac Discussion Tools | | |
Censor is ON | | | |
