| Northstar Performance and Technical Discussion Performance discussions relating to the Northstar System (intake, exhaust, cam, etc.). | Cadillac Forums: Block Sealer??
02-26-08, 01:06 PM
| | Cadillac Owners Member Cadillac(s): 1997 Eldorado, 1969 Coupe Deville | | Join Date: Jul 2007 Location: Auburn, NY Age: 25 | | | Block Sealer?? Has anybody ever tried using any type of additive to stop a leaky head gasket? Got some stuff today that i am going to try before pulling apart the motor, and or replacing it. |
02-26-08, 01:41 PM
|  | If it won't run, chrome it..... Cadillac(s): 2002 Cadillac F55 STS/53000mi., 2004 Ford F150 Super cab 4x4 | | Join Date: Feb 2006 Location: Maryland upper Eastern Shore Age: 69 | | | Re: Block Sealer?? Your exact question has been discussed in here and in Seville/Deville endlessly. The general consensus from all sorts of mechanics and engine builders is that, while some sealers might work for a little while, your best bet is to bite the bullet and do the engine head work properly.
What car, what engine, what year ???? Different answers.... |
02-26-08, 09:13 PM
| | Cadillac Owners Connoisseur Cadillac(s): Member of Air Fuel Tuning (Cadillac Division) | | Join Date: Apr 2007 Location: Inside The Northstar PCM Age: 41 | | | Re: Block Sealer?? |
02-27-08, 01:38 PM
|  | Cold Soaked Cadillac(s): 2006 STS AWD, '95 Ford Ranger | | Join Date: Jul 2004 Location: Fairbanks, Ak Age: 70 | | | Re: Block Sealer?? You'd do less damage to the car if you drained all the water out and drove it around in "limp home" mode.
__________________ Don't mess with Binky Bear! |
02-27-08, 02:50 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 1997 ETC, 2000 DTS | | Join Date: Jul 2007 Location: FOUNTAIN HILLS, AZ Age: 53 | | | Re: Block Sealer?? AJ - my head gaskets looked pretty much just like that - I posted them on my ETC HG project thread - I never added anything but the recommended GM pellets. Do you think the pellets are a bad idea?
Richard Moore |
02-27-08, 11:11 PM
|  | Cadillac Owners Fanatic Cadillac(s): 1998 STS, 2004 Dodge 3500 Cummins | | Join Date: Sep 2007 Location: Stephenville, Texas Age: 53 | | | Re: Block Sealer?? Anything remotely strong enough to stop a headgasket leak, will stop up your radiator or heatercore first. Or the above headgaskets.
Bill |
02-28-08, 11:27 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: Block Sealer?? Quote:
Originally Posted by tateos AJ - my head gaskets looked pretty much just like that - I posted them on my ETC HG project thread - I never added anything but the recommended GM pellets. Do you think the pellets are a bad idea?
Richard Moore | Don't mean to answer for AJ, but they should not hurt anything. |
02-29-08, 12:26 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 1997 ETC, 2000 DTS | | Join Date: Jul 2007 Location: FOUNTAIN HILLS, AZ Age: 53 | | | Re: Block Sealer?? That's what I thought Ranger, but like I said, the pictures AJ posted looked just like my gaskets |
02-29-08, 01:24 PM
02-29-08, 04:49 PM
|  | If it won't run, chrome it..... Cadillac(s): 2002 Cadillac F55 STS/53000mi., 2004 Ford F150 Super cab 4x4 | | Join Date: Feb 2006 Location: Maryland upper Eastern Shore Age: 69 | | | Re: Block Sealer?? AJ...........Look at your last post, #9. Are you saying that GM has dropped the requirement to use the GM Supplement tablets in 2002 and prior year Northstar vehicles as part of a recommended coolant change ??
I called my tech friend at Fitzgerald Cadillac in Annapolis and he says there's no TSB on this change.
What's up ?? |
02-29-08, 09:54 PM
| | Cadillac Owners Connoisseur Cadillac(s): Member of Air Fuel Tuning (Cadillac Division) | | Join Date: Apr 2007 Location: Inside The Northstar PCM Age: 41 | | | Re: Block Sealer?? Quote:
Originally Posted by submariner409 AJ...........Look at your last post, #9. Are you saying that GM has dropped the requirement to use the GM Supplement tablets in 2002 and prior year Northstar vehicles as part of a recommended coolant change ??
What's up ?? | I am in Vegas. When I get home I will dig out the info. I is in a training manual. |
02-29-08, 11:04 PM
|  | If it won't run, chrome it..... Cadillac(s): 2002 Cadillac F55 STS/53000mi., 2004 Ford F150 Super cab 4x4 | | Join Date: Feb 2006 Location: Maryland upper Eastern Shore Age: 69 | | | Re: Block Sealer?? AJ, I strongly recommend you go back and read your posted note from last September as pertains to Northstars and seal tablets. Your blanket post ^^ which basically says "DON'T" is flat wrong.
Is the article you posted from GM Engineering ? Is the article you posted from GM Corporate ?
Show me the GM TSB that rescinds the requirement to use the GM approved coolant supplement in specific Northstar installations.
I want, in public forum, in this thread, an absolute statement from you, who represent General Motors, that the coolant system supplement tablets are not recommended in any Northstar installation. The members of CadillacForums deserve no less. |
03-01-08, 12:09 AM
|  | Cadillac Owners Connoisseur Cadillac(s): 1997 ETC, 2000 DTS | | Join Date: Jul 2007 Location: FOUNTAIN HILLS, AZ Age: 53 | | | Re: Block Sealer?? The bulletin does say this, which I interpret as meaning DO use the tabs in N*s TIP: If seal tabs were installed in a vehicle at the factory, it’s OK that the proper amount of tabs be installed if the coolant must be drained and replaced. |
03-01-08, 12:51 AM
| | Cadillac Owners Connoisseur Cadillac(s): 02 STS | | | | | Re: Block Sealer?? Quote:
Originally Posted by submariner409 AJ, I strongly recommend you go back and read your posted note from last September as pertains to Northstars and seal tablets. Your blanket post ^^ which basically says "DON'T" is flat wrong.
Careful Sub!
I once questioned the exalted AJ and got my head bit off by old timers and newbie's alike... He is NEVER wrong.
If he says not to use tabs that's good enough for me!
No documentation is required! | | Cadillac Discussion Tools | | |
Censor is ON | | | |
