Results 1 to 9 of 9
Thread: 97 Deville w/ N* Battery(?) problems
    Mar 2006
    11
    Ok to start off hear are my symptoms
    -No elecetrical Power
    -Battery gets good charge reading when hooked up to charger
    -Car gets half power when hooked up the charger
    Ok now some background, 97 deville 195k miles, 1st new battery put in 4 month ago about two weeks ago woke up one morning and got a no start. Put the car on the battery charger let charge for one day next day car ran fine doing errands and stuff throughout the day, but next morning no start again, so went back to Walmart and got a warranty replacement battery. Put battery in, but no start, but the car was getting power. Next day i searched online and found something about reprogramming the key smart chip by having ing on for 10 then off, then on again for 10 .... did that and car cranked but still no start so put it on the charger and within a few minutes in started right up. Car ran fine for about 3 days and woke up this morning and no start or power to the car again. When i hook the charger to the battery it reads that it is about 14volts and the car gets power in the dash but its flickering. Not sure what to try at this point any direction would be great thanks in advance.
    69
    82,262
    Re: 97 Deville w/ N* Battery(?) problems
    Make sure that the cables are clean and tight.
    Mar 2006
    11
    The cables are tight I am sure of that maybe corrosion, but I cleaned them earlier this week it was dark when I did it so i guess i could have not gotten all of it, but could it re-corrode that fast? thanks
  5. #4
    69
    82,262
    No, but if there was a lot of corrosion it could have gotten under the insulation, so check it closely.
  6. #5
    Mar 2006
    11
    Ok used baking soda and water on the battery and im still getting nothing unless the battery is hooked up to the charger. Also now when the charger is connected I get a click click click every few seconds coming from the right above the driver side wheel well where all the fuses are. I am lost on this I thought maybe it was a bad ground but I regrounded part of it and it still does the same thing. Oh and thanks for the help ranger hopefully i will get her running again.
  7. #6
    69
    82,262
    See if you can locate that click. Maybe a bad relay? Not sure, but I think I recall a starter enable relay.
  8. #7
    Mar 2006
    11
    Sounds/feels like the click is coming from the inadvert power relay. Maybe its a bad relay, but can this relay cause enough trouble that the car gets no power at all(dash, seats, windows, etc), thanks for the help.
  9. #8
    69
    82,262
    Not sure. Swap it with another relay to eliminate it.
  10. #9
    Mar 2006
    11
    Replacing the relay made me be able to get the car back running but after I replaced it the car would run fine for a day and the battery would die overnight. After alittle searching I found that the Power antenna stopped working and was constantly draining power from the car, so I just unplugged the antenna and everything seems to be working fine now. Thanks for your help Ranger even though it turned out to be something dumb, I appreciate your help.
  • You may not post replies
