| Northstar Performance and Technical Discussion Performance discussions relating to the Northstar System (intake, exhaust, cam, etc.). | Cadillac Forums: 97 Etc N* Head Gasket Project
01-28-08, 09:40 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: 97 Etc N* Head Gasket Project Geez, as if you do not have enough problems. Murphy's law. |
01-28-08, 10:43 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 1996 Eldorado Sport Coupe | | Join Date: Jul 2005 Location: Chicago | | | Re: 97 Etc N* Head Gasket Project I don't have much to add besides great documentation as this thread will help many(not me I hope/pray). |
01-29-08, 09:48 AM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: Ouch! Quote:
Originally Posted by tateos I have good news and bad news. The good news is the Norm's inserts are plenty stong. The bad news:
Over the weekend, I was torquing down the left bank cylinder head, and I got to the last 60 degrees and when I got to bolt 9, it suddenly started to get EASIER to turn. This was the first hole I had drilled and tapped, and when the insert was installed all the way to the bottom, it was a little deeper than it should have been. I installed the insert to the proper depth, but I thought maybe the loctite had let go when I was tightening the bolt and the insert was turning. I checked the torque on the rest of the bolts and they were around 80 ft pounds, so I decided to try turning bolt 9 until I reached 80 ft pounds, but the more I turned it, the EASIER it got to turn - until the bolt snapped!
I removed the other 9 bolts and the head and was eventually able to get the remainder of the head bolt out with an easy- out. I found that the insert had not turned at all - it was at the same depth as I had set it! I re-installed the head and inserted and tightened the other set of bolts - the ones I had bought for the right bank. This time everything went just fine.
I don't understand what went wrong... could it have been a defective bolt? I plan on ordering a new set of Fel-Pro bolts for the right bank - I got them from Rock Auto - $28.79 per bank | I had a similar thing happen. That's why I was thinking about stopping at 45 degrees on the last pass (if I ever do another one). All but one of mine went above 90 ft-lbs. One seemed to "yeild" and only got to about 88 lb-ft. I was uncomfortable with it, but I left it in anyway and so far (6k miles) it is ok. I suspected the insert turning or stripping threads too. But after reading your post, I think my bolt was begining to fail too.
I think the Norm's inserts provide much greater holding power than the original aluminum threads. This puts a lot more stress on the unused section of the bolt threads between the bolt shank and the insert. Once this portion begins to yeild, there is very little warning before it fails. Rockauto bolt quality is probably less consistant than OEM too. |
01-29-08, 11:00 AM
|  | If it won't run, chrome it..... Cadillac(s): 2002 Cadillac F55 STS/53000mi., 2004 Ford F150 Super cab 4x4 | | Join Date: Feb 2006 Location: Maryland upper Eastern Shore Age: 69 | | | Re: 97 Etc N* Head Gasket Project Unfortunately bolts are no longer made of anything approaching uniform quality because the majority are made overseas. I have no idea where GM/Ford get their bolts from, but I'll bet the farm it ain't Taiwan.
For our Olds 455 boat engines we use exclusively ARP, and have great results. I have no idea if they make N* bolts or kits. Worth a phone call.
Not cheap, though....... |
01-29-08, 12:15 PM
| | Cadillac Owners Fanatic Cadillac(s): '03 SLS, '01 Trans Am | | Join Date: Jan 2008 Location: New York | | | Re: 97 Etc N* Head Gasket Project ARP would be a great option if they have bolts that will work with an N*. I used them in my LS1 and got rid of the pain in the butt torque-to-yield factory style bolts. I didn't like the idea of repeatedly cranking on headbolts in an aluminum block as hard as was required for TTY bolts. The ARP's should clamp better, and be a bit easier on the N* block threads. |
01-29-08, 12:39 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 1997 ETC, 2000 DTS | | Join Date: Jul 2007 Location: FOUNTAIN HILLS, AZ Age: 53 | | | Re: 97 Etc N* Head Gasket Project 97CONCOURS1 - you bring up a good point I had not thought of - the bolt DID break above the insert - I never really thought about that - there were only about 5 threads left on the bolt. As tight as these bolts are tightened, I am surprised the aluminum EVER held. The FSM does specify just two 60 degree turns after the initial torqueing, but that has been revised to 3 60 degree turns (or is it 2 60s and a 70?), so maybe that is why the aluminum was strong enough from the factory. |
01-30-08, 10:23 PM
| | Cadillac Owners Connoisseur Cadillac(s): Member of Air Fuel Tuning (Cadillac Division) | | Join Date: Apr 2007 Location: Inside The Northstar PCM Age: 41 | | | Re: 97 Etc N* Head Gasket Project I found a set of heads on ebay. Guess what came out with these bolts?  |
01-31-08, 01:14 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 1997 ETC, 2000 DTS | | Join Date: Jul 2007 Location: FOUNTAIN HILLS, AZ Age: 53 | | | Re: 97 Etc N* Head Gasket Project AJ - that looks familiar.
I guess I have to make a confession to you guys. I left this out of my posts so far, but when I removed the head, after breaking the bolt, one of the OTHER bolts came out with the insert still attached. It did not strip - it just unscrewed. I apparently forgot to apply Loctite to that insert, and the sealer on the bolts was strong enough to hold the insert and cause the insert to turn out. I installed the extra insert that Norm supplies, with Loctite this time, and everything went fine. |
01-31-08, 10:46 PM
| | Cadillac Owners Member Cadillac(s): 1999 Seville Cadillac | | Join Date: Jan 2008 Location: Arizona | | | Re: 97 Etc N* Head Gasket Project Tateos... I'm glad you have this thread. I just bought a 99 Seville for a song and dance last weekend 'cause it has a bad HG and a botched re-paint on the passenger side. I originally planned to use the N* for my Jeep and part the rest of the car out but... WOW.. it's a nice car and I don't have the heart to gut it. The plan now is to fix the motor, fix the botched Maaco repaint and sell it. I took the motor out last weekend (yeah... what a pain). I WAS planning to replace the head gaskets this weekend and get the motor back in the car UNTIL I read you post. I have replaced many a head gasket but the N* seems to be quite a different animal. I don't have a service manual and was hoping to "work" my way through it. Like everyone said... the Haynes manual isn't exactly a wealth of information on this. I have a couple of questions: 1. The Haynes manual tells you how to do MOST of the "sub-tasks" as far as I can tell... is there something I will miss without the service manual? I don't really want to spend the money if I don't have to for 1 job. 2. The rear head is the problem... is there any reason why I should do the front head? AND 3. What are the chances I can get away with replacing the head without installing inserts? If all of the headbolts come out clean when i remove them is it even worth trying? |
01-31-08, 11:14 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: 97 Etc N* Head Gasket Project Just my $0.02
Do both heads while the motor is out. Don't attempt it without Timeserting. Some threads may pull on final torquing or will likely fail later. I realize you are going to sell it, but personally I would rather do the job right and sell it with a clean conscience. |
01-31-08, 11:29 PM
| | Cadillac Owners Member Cadillac(s): 1999 Seville Cadillac | | Join Date: Jan 2008 Location: Arizona | | | Re: 97 Etc N* Head Gasket Project Ranger... I'm not trying to sell anyone a lemon or I would have just put some barsleak in it and called it a day. Thank's for the advice. Like I said, it is a really nice car (I don't know how many cows had to die for that interior). Does anyone know the best deal for the timeserts? |
02-01-08, 12:08 AM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: 97 Etc N* Head Gasket Project Don't misunderstand me, I didn't mean to imply that you were. http://www.timesert.com.
You might find a used kit on Ebay. Probably have to get the serts from Timesert. Or you might try Norms inserts on ebay. AJ seems to like them much better. |
02-01-08, 12:29 AM
| | Cadillac Owners Connoisseur Cadillac(s): '05 Dodge RAM Daytona, 96 Dodge B1500 van,'05 Suzuki Forenza | | Join Date: Oct 2003 Location: Florida Age: 38 | | | Re: 97 Etc N* Head Gasket Project Quote:
Originally Posted by krechtr Tateos... I'm glad you have this thread. I just bought a 99 Seville for a song and dance last weekend 'cause it has a bad HG and a botched re-paint on the passenger side. I originally planned to use the N* for my Jeep and part the rest of the car out but... WOW.. it's a nice car and I don't have the heart to gut it. The plan now is to fix the motor, fix the botched Maaco repaint and sell it. I took the motor out last weekend (yeah... what a pain). I WAS planning to replace the head gaskets this weekend and get the motor back in the car UNTIL I read you post. I have replaced many a head gasket but the N* seems to be quite a different animal. I don't have a service manual and was hoping to "work" my way through it. Like everyone said... the Haynes manual isn't exactly a wealth of information on this. I have a couple of questions: 1. The Haynes manual tells you how to do MOST of the "sub-tasks" as far as I can tell... is there something I will miss without the service manual? I don't really want to spend the money if I don't have to for 1 job. 2. The rear head is the problem... is there any reason why I should do the front head? AND 3. What are the chances I can get away with replacing the head without installing inserts? If all of the headbolts come out clean when i remove them is it even worth trying? | So you are attempting to do a $3000-$4500 repair on a $2-$3k car?. LOL, good luck.  |
02-01-08, 04:06 AM
| | Cadillac Owners Connoisseur Cadillac(s): 1997 Eldorado | | Join Date: Apr 2005 Location: Oakland County, MI Age: 26 | | | Re: 97 Etc N* Head Gasket Project Quote:
Originally Posted by Destroyer So you are attempting to do a $3000-$4500 repair on a $2-$3k car?. LOL, good luck.  | It's not even a $1000 repair if he does it himself. |
02-01-08, 02:57 PM
| | Cadillac Owners Member Cadillac(s): 1999 Seville Cadillac | | Join Date: Jan 2008 Location: Arizona | | | Re: 97 Etc N* Head Gasket Project Quote:
Originally Posted by Destroyer So you are attempting to do a $3000-$4500 repair on a $2-$3k car?. LOL, good luck.  | They are going for between $5 and $10K on Craigslist... plus I'm a pretty good salesman. I guess if took it to a shop they may charge me $2 or $3K but if I took my cars to the shop I wouldn't be spending time in this forum. I got all the info last night I need from another website to fix this without a manual. Even with paint, parts and buying a NEW timesert kit I will have less than a grand in this car... worst case, I will cut it up and still make money. Want to buy some leather seats? What?
Ranger.... I didn't misunderstand you... you were right and I appreciate your advice. I like to think of myself as a quasi-perfectionist so I want the job done right. I talked to a caddy tech and he told me that I only need to replace any bad threads and the threads that surround them. Since I have to buy the timesert kit anyway just for this job, however, I am just going to go ahead and do them all. | | Cadillac Discussion Tools | | |
Censor is ON | | | |
