cadillac
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Cadillac Technical Archive | Cadillac Dealers | Cadillac Reviews | Cadillac Dealer Reviews | Cadillac Vendors | Decals
gm social network
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 15 of 48
Northstar Performance and Technical Discussion Discussion, Engine Oil Myths including ZDP by GM in Cadillac Engine Technical Discussion; Over the years there has been an overabundance of engine oil myths. Here are some facts you may want to ...
    AJxtcman's Avatar
    AJxtcman is offline Cadillac Owners Connoisseur
    Automobile(s): The Northstar Tuner
    Apr 2007
    Rock Hill SC
    43
    2,699
    Over the years there has been an overabundance of engine oil myths. Here are some facts you may want to pass along to customers to help debunk the fiction behind these myths.
    The Pennsylvania Crude Myth -- This myth is based on a misapplication of truth. In 1859, the first commercially successful oil well was drilled in Titusville, Pennsylvania.
    A myth got started before World War II claiming that the only good oils were those made from pure Pennsylvania crude oil. At the time, only minimal refining was used to make engine oil from crude oil. Under these refining conditions, Pennsylvania crude oil made better engine oil than Texas crude or California crude. Today, with modern refining methods, almost any crude can be made into good engine oil.
    Other engine oil myths are based on the notion that the new and the unfamiliar are somehow "bad."
    The Detergent Oil Myth -- The next myth to appear is that modern detergent engine oils
    are bad for older engines. This one got started after World War II, when the government no longer needed all of the available detergent oil for the war effort, and detergent oil hit the market as “heavy-duty” oil.
    Many pre-war cars had been driven way past their normal life, their engines were full of sludge and deposits, and the piston rings were completely worn out. Massive piston deposits were the only thing standing between merely high oil consumption and horrendous oil consumption. After a thorough purge by the new detergent oil, increased oil consumption was a possible consequence.
    If detergent oils had been available to the public during the war, preventing the massive deposit buildup from occurring in the first place, this myth never would have started. Amazingly, there are still a few people today, 60 years later, who believe that they need to use non-detergent oil in their older cars. Apparently, it takes many years for an oil myth to die.
    The Synthetic Oil Myth -- Then there is the myth that new engine break-in will not occur with synthetic oils. This one was apparently started by an aircraft engine manufacturer who put out a bulletin that said so. The fact is that Mobil 1 synthetic oil has been the factory-fill for many thousands of engines. Clearly, they have broken in quite well, and that should put this one to rest.
    The Starburst Oil Myth -- The latest myth promoted by the antique and collector car press says that new Starburst/ API SM engine oils (called Starburst for the shape of the symbol on the container) are bad for older engines because the amount of anti-wear additive in them has been reduced. The anti-wear additive being discussed is zinc dithiophosphate (ZDP).
    Before debunking this myth, we need to look at the history of ZDP usage. For over 60 years, ZDP has been used as an additive in engine oils to provide wear protection and oxidation stability.
    ZDP was first added to engine oil to control copper/lead bearing corrosion. Oils with a phosphorus level in the 0.03% range passed a corrosion test introduced in 1942.
    In the mid-1950s, when the use of high-lift camshafts increased the potential for scuffing and wear, the phosphorus level contributed by ZDP was increased to the 0.08% range.
    In addition, the industry developed a battery of oil tests (called sequences), two of which were valve-train scuffing and wear tests.
    A higher level of ZDP was good for flat-tappet valve-train scuffing and wear, but it turned out that more was not better. Although break-in scuffing was reduced by using more phosphorus, longer-term wear increased when phosphorus rose above 0.14%. And, at about 0.20% phosphorus, the ZDP started attacking the grain boundaries in the iron, resulting in camshaft spalling.
    By the 1970s, increased antioxidancy was needed to protect the oil in high-load engines, which otherwise could thicken to a point where the engine could no longer pump it. Because ZDP was an inexpensive and effective antioxidant, it was used to place the phosphorus level in the 0.10% range.
    However, phosphorus is a poison for exhaust catalysts. So, ZDP levels have been reduced over the last 10-15 years. It's now down to a maximum of 0.08% for Starburst oils. This was supported by the introduction of modern ashless antioxidants that contain no phosphorus.
    Enough history. Let's get back to the myth that Starburst oils are no good for older engines. The argument put forth is that while these oils work perfectly well in modern, gasoline engines equipped with roller camshafts, they will cause catastrophic wear in older engines equipped with flat-tappet camshafts.
    The facts say otherwise.
    Backward compatability was of great importance when the Starburst oil standards were developed by a group of experts from the OEMs, oil companies, and oil additive companies. In addition, multiple oil and additive companies ran no-harm tests on older engines with the new oils; and no problems were uncovered.
    The new Starburst specification contains two valve-train wear tests. All Starburst oil formulations must pass these two tests.
    - Sequence IVA tests for camshaft scuffing and wear using a single overhead camshaft engine with slider finger (not roller) followers.
    - Sequence IIIG evaluates cam and lifter wear using a V6 engine with a flat-tappet system, similar to those used in the 1980s.
    Those who hold onto the myth are ignoring the fact that the new Starburst oils contain about the same percentage of ZDP as the oils that solved the camshaft scuffing and wear issues back in the 1950s. (True, they do contain less ZDP than the oils that solved the oil thickening issues in the 1960s, but that's because they now contain high levels of ashless antioxidants not commercially available in the 1960s.)
    Despite the pains taken in developing special flat-tappet camshaft wear tests that these new oils must pass and the fact that the ZDP level of these new oils is comparable to the level found necessary to protect flat-tappet camshafts in the past, there will still be those who want to believe the myth that new oils will wear out older engines.
    Like other myths before it, history teaches us that it will probably take 60 or 70 years for this one to die also.
    Special thanks to GM's Techlink
    - Thanks to Bob Olree – GM Powertrain Fuels and Lubricants Group
    http://216.182.211.32/techlink/image...7e.html#story1
    GM technician since 1999
    Mopar Tech from 93 to 99
    Over 350 GM training courses
    Tuning thread since 4/23/07
    Hometown Washougal WA
  2. Cadillac Network Advertisements Registered members do not see these ads. Click here to remove them.
    Always
    Advertising world
    2010
    Many
    ncCADDYman is offline Cadillac Owners Member
    Automobile(s): 2008 CTS (hopefully soon)
    Sep 2007
    Charlotte, NC
    31
    86
    Re: Engine Oil Myths including ZDP by GM
    damn, i feel educated after reading that post ... thanks
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    72
    23,286
    That is why the OLM system was developed by observing the operating conditions that depleted ZDP and finding a way to quantify the remaining ZDP by calculation with the ECM. The OLM knows the amount of ZDP the oil starts with and what depletes it. It keeps track of these factors and lets you know when the ZDP needs to be replenished by an oil change.
    Don't mess with Binky Bear!
  5. Sponsored Cadillac Advertisements (Supporting Members don't see these ads)
    iroc86 is offline Cadillac Owners Member
    Jun 2005
    87
    I saw that article a few days ago on GM TechLink. With all the talk regarding the new oil specifications, it was an interesting read... especially since it's straight from an automaker.
    Cadillacboy's Avatar
    Cadillacboy is offline Cadillac Owners Connoisseur
    Automobile(s): 1996 Cadillac Fleetwood Brougham
    Dec 2003
    31
    3,825
    Another oil thread
    AJxtcman's Avatar
    Apr 2007
    Rock Hill SC
    43
    2,699
    Quote Originally Posted by iroc86 View Post
    A few weeks back I changed my oil. I kind of stopped driving the car after that. I might have 40 miles on it since. I asked the parts guys to get me some EOS. No can do To add to that we switch oils about 2 or 3 months ago and it come out of the gun with the consistency of mineral spirits. Yeah it is very thin and clear as good water on the other hand our water is black now.
    My motor had about 6k on it when I had my issues and had to swap blocks and one head. When I did this repair I found major lifter wear The oil that was put in that motor when new was GF-4, but I think it was 10W-30. Maybe we have 5W-30? I thought we had 5W-30 before that went to the runny stuff.
    Anyway I have been scared that I am damaging my cams. Now I am sure that I am. You have to realise that the engine is inches from my head and the ambient temp is low, so this loud a$$ Northstar is rattling away.
    I will look for a new source of oil.
    EcSTSatic's Avatar
    EcSTSatic is offline Cadillac Owners Connoisseur
    Automobile(s): 1999 STS - diamond white
    Dec 2004
    Wichita, KS
    4,028
    I hate perpetuating yet another oil thread but this question has bothered me. Maybe someone can ease my angst. How does one know that the OLM is working properly? Is there a self-test or something? Will I always be able to rely on it?
    AJxtcman's Avatar
    Apr 2007
    Rock Hill SC
    43
    2,699
    Quote Originally Posted by EcSTSatic View Post
    This may shed some light
    http://www.cadillacforums.com/forums...does-know.html
    clarkz71's Avatar
    clarkz71 is offline Cadillac Owners Connoisseur
    Automobile(s): 1994 Mercedes E420 / 1995 Eldorado/ 2006 Yamaha R1 LE
    Mar 2006
    Clearwater Beach, Florida
    48
    1,261
    I'll stick with Rotella 10/30.
    AJxtcman's Avatar
    Apr 2007
    Rock Hill SC
    43
    2,699
    Quote Originally Posted by clarkz71 View Post
    If I didn't I was going to PM you about EOS. I thought GM had a new listing under engine assembly lube.
    Now I looked at the oil tanks today. The oil is listed as GF-4, 5W-30, Synblend. The tank also has a sticker for GF-4, 10W-30 supreme. I am thinking it is a seasonal thing and this season has not come yet
    The 5W-30 is probably out of season, so it is probably on sale. That 5 cent they are saving is going to help
    clarkz71's Avatar
    Mar 2006
    48
    1,261
    Quote Originally Posted by AJxtcman View Post
    New formula EOS. Part# 88862586
    Jun 2005
    87
    You guys should have stocked up on the EOS a couple months back. I have about fifteen bottles of the old formula. The 396 in my '67 Camaro has a flat-tappet cam, and I do not trust the new SM standard yet. Even the diesel oils, such as Mobil Delvac, aren't as potent as they once were. It'll be interesting to see if the new anti-wear formulations are as good as ZDP in real-world usage. Considering that the move towards lessening ZDP was brought on to avoid catalyst damage, I'm not holding my breath.
    Feb 2004
    FL
    2,250
    Put some context in....
    What benefit does GM have to keep our older (>10years old, out of warranty) cars on the road? Wouldn't it be better if all of our cars blew up, so we'd be forced to drive the newest models? Planned obsolescence? Conspiracy theory? ehh... I like my ZDDP, until someone proves "beyond a reasonable doubt" that it's either not necessary or causing damage. This means I want numbers!!
  16. #14
    EcSTSatic's Avatar
    Dec 2004
    Wichita, KS
    4,028
    That's good information but the question is how do you know that the OLM sensors are working properly? Are there OLM error codes in the DIC?
  17. #15
    Jun 2005
    87
    I'm just taking a stab in the dark here, but I bet the PCM would throw a checksum error if the OLM code wasn't working. Keep in mind that the OLM bases its calculations from various engine sensors, so if one of those went bad, it would display a DTC for that particular sensor.
    Outside of those sensors, the OLM is just a program inside the PCM that calculates the estimated oil life from a set of mathematical algorithms. I surmise the only thing that would really cause the OLM to fail is PCM data corruption (and you'd probably have a bunch of other problems besides the OLM not working!). I'm not sure how Cadillac does it, but most other PCMs will perform a quick test at key-on to ensure the code and calibration data are intact. It's called a "checksum," and is really nothing more than comparing the code against an expected value.
Sponsored Cadillac Ads - Click here to show your support and REMOVE advertisements!
  • You may not post replies
Read about Cadillac ATS | Cadillac ATS Forum | Lincoln | Buick | Hyundai Genesis Forum | Kia Forte Forum
custom floor mats | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods | Cadillac Chrome and Black Chrome Wheels | window tinting
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239
