Page 1 of 2 12 LastLast
Results 1 to 15 of 19
Thread: 2003 DHS - Sluggish - EGR?
    Jan 2006
    13
    My son's 2003 DHS had been running fine but after he filled-up the caddy and few miles down the road it began running sluggish, knocking...at WOT the RPMs run up but shifting is slow and it does not get down the road as you would expect with WOT.
    Easing into the throttle the caddy drives and shifts fne and will operate at hwy speeds. We put some fuel cleaner in and are running the fuel out.
    Any thoughts? Just bad fuel, sticking EGR valve? We haven't checked for thrown codes yet but plan to.
    dkozloski's Avatar
    dkozloski is online now Cadillac Owners 10000+ Posts
    Jul 2004
    Fairbanks, Ak
    28,283
    Re: 2003 DHS - Sluggish - EGR?
    It sounds like he put diesel in it. Did the pump hose have a green handle?
    Don't mess with Binky Bear!
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,808
    Diesel......best guess. Slug of water from low station tank.......maybe. Car.......probably not.
  5. #4
    Jan 2006
    13
    Well, the diesel nozzle should not fit but incase he did put some diesel...what would the outcome be. Simply run the fuel out or drain?
  6. #5
    69
    82,262
    Doubt that is the case. If there was too much diesel it probably would not even run.
  7. #6
    Jan 2006
    13
    Yeah, it does not smoke just won't get up and go. RPMS run up where there supposed to be at WOT but the caddy is just moving like it should. Rolling at about 30 and going to WOT it downshifts and RPMS go up and it accelerates but not anything like it should.
    Any more thougts?
  8. #7
    Jan 2006
    13
    Yeah, it does not smoke just won't get up and go. RPMS run up where there supposed to be at WOT but the caddy is just [U]not moving like it should. Rolling at about 30 and going to WOT it downshifts and RPMS go up and it accelerates but not anything like it should.
    Any more thougts?
  9. #8
    Sep 2003
    Metro ATL
    4,854
    Trouble codes might provide a clue. Here is how to display trouble codes (DTCs):
    http://www.cadillacforums.com/forums...s-warning.html
  10. #9
    69
    82,262
    Plugged CAT? Any DTC's?
  11. #10
    NoMaBeach is offline Cadillac Owners Member
    Automobile(s): 1998 DeVille, 2003 DTS
    Aug 2004
    Sonoma California USA
    29
    Try the fuel filter. I change mine every 15k.
  12. #11
    Sep 2003
    Metro ATL
    4,854
    Good grief!
  13. #12
    69
    82,262
    My sentiments exactly Jim.
  14. #13
    Feb 2006
    56,808
    Something escapes me............
  15. #14
    Sep 2003
    Metro ATL
    4,854
    Quote Originally Posted by submariner409 View Post
    Read Post #10.
  16. #15
    Feb 2006
    56,808
    I did before I posted.
    (as an aside, I got antsy and replaced the fuel filter at 43,000 on my '02 in Sept. Cut old one open. Looked like I had put it in the day before. Dead nuts clean. Non-issue.)
  • You may not post replies
