Originally Posted by zonie77 bbob had a hose to check, possibly the bypass, to ensure it wasn't clogged. You'll have to search the threads or see if he adds to this one. |
That would be the small one that comes through the motor lift bracket. Make sure it is clear from end to end (gos from there under the intake to the purge resovior).
Also make sure the water pump belt and tensioner are good. That tensioner freezes up and doesn't apply enough pressure and lets the belt slip.
Also make sure both the rad fans are working. They should come on at about 228 (I think) and off at about 212. You can check real fast by turning on the AC. With the AC on they should both always run. But also make sure they are coming on by themselves without the AC on.
If both the radiator hoses are hot I would say that the rad is OK. Might have a problem if one were significantly warmer than the other, but thats not the case.
If these items check OK test for a head gasket leak. As Zonie said, do a search, for "head gasket test" by user "bbob". Should be plenty posted already for that. You'll be looking for coolant in the cylinders. And a loss of compression.
You really wouldn't notice any smoke or anything out the exaust. And they don't usualy leak into the oil. The most common symton is after the car sitting overnight, you may notice it misses for a few munites when you start it. As the coolant fills the cylinder after it sits awhile. In severe cases it can hydro lock the cylinder and cause the starter to groan and "catch". And worse let even bend a rod.
I assume there are no external leaks?
