Go Back   Cadillac Owners Group > General Discussion > Cadillac Engine Technical Discussion > Northstar Performance and Technical Discussion
Northstar Performance and Technical Discussion Performance discussions relating to the Northstar System (intake, exhaust, cam, etc.).
Cadillac Forums: Northstar Headgasket/Bolt Failure? Please let us know
View Poll Results: Select one if you have had a problem with the headgasket the Northstar V8:
1993 10 2.62%
1994 29 7.61%
1995 9 2.36%
1996 22 5.77%
1997 83 21.78%
1998 90 23.62%
1999 90 23.62%
2000 26 6.82%
2001 16 4.20%
2002 13 3.41%
2003 5 1.31%
Multiple Choice Poll. Voters: 381. You may not vote on this poll
  #256 (permalink)
Old 08-25-09, 09:43 PM
Cadillac(s): 1997 Seville SLS
View scttsmn's Photo Album
Casino Cash: $275
Re: Northstar Headgasket/Bolt Failure? Please let us know
Originally Posted by MrEldo97 View Post
"Aha ... "timeserting" = installing helical inserts (Heli-Coils, etc) ... never heard that one."
Do your homework on timeserts and then rejoin the discussion...
Does the engine have to be removed to install an insert kit such as the NS300L?
  #257 (permalink)
Old 08-25-09, 09:55 PM
Cadillac(s): 96 deville,94 eldorado touring coupe
View robertcopeland69's Photo Album
Casino Cash: $505
96 deville with 252,000 miles.had 129,000 when i got it.i havent had a headgasket failure.could have been replaced before i got it though.
  #258 (permalink)
Old 09-02-09, 12:22 AM
postman2000's Avatar
Cadillac(s): 2000 cadillac deville
View postman2000's Photo Album
Casino Cash: $1200
i have a 2000 deville.. head gaskets went at 102,000.. 3 months ago.. charlie
  #259 (permalink)
Old 09-03-09, 06:17 PM
M.A.C's Avatar
Cadillac(s): 2005 STS, V8
View M.A.C's Photo Album
Casino Cash: $695
The problem with this pole configuration is that it doesn't have an option to select "No", as in no head gasket problem.
I would set it up with 'Yes' and 'No' choices as follows:
1994 Yes/No
1995 Yes/No
1996 Yes/No
etc.
  #260 (permalink)
Old 09-05-09, 09:23 PM
Cadillac(s): 2000 Seville STS
View osu411yamaha's Photo Album
Casino Cash: $1780
1994 Yes/No
1995 Yes/No
1996 Yes/No
etc.
Yes this is the most biased poll I have ever seen. Any statistician would laugh at it. The results are so skewed its not even funny. It is setup so only people with the problem can respond. Definitely need a yes and no.
  #261 (permalink)
Old 09-05-09, 09:45 PM
Cadillac(s): 1999 Cadillac Seville STS
View jcresciSTS's Photo Album
Casino Cash: $1870
How can you respond No when it can still happen?
  #262 (permalink)
Old 09-07-09, 01:51 AM
N*Caddy's Avatar
Cadillac(s): 1997 Cadillac STS
View N*Caddy's Photo Album
Casino Cash: $11500
From the first glance looking to the pole results I see a very logical result:
Most of the cars with HG problems are ‘97-‘99 with a drop on the older and newer cars.
The drop on the older cars is because there are not so many left and if the problem happens is less likely to be repaired. While with the newer cars is either because they have not enough mileage accumulated or the problem was indeed fixed.
I bet next year ’97 will be somewhere below 10% and 2000 will likely go up sharply.
This pole should be seen as a count, you don’t have an issue you don’t participate.
That being said ’97 STS little over 120K miles no issue yet (knock on wood).
  #263 (permalink)
Old 09-11-09, 02:51 AM
Cadillac(s): 2002 Cadillac Seville STS
View JSTS02's Photo Album
Casino Cash: $1180
2002 Seville STS with a head gasket failure....
all it took was a cracked radiator for a month....running it on water during that time might not have helped...
After replacing the radiator, it really blew out a few weeks after during a 1500+ mile trip...
a tech will be digging in to replace using the Norms Kit tomorrow... so i'll know exactly what happened... i'm anxious to see my block apart!!! ... read all about it in the post below...
http://www.cadillacforums.com/forums...lure-best.html (NEW - 2002 Head Gasket Failure - Best Fix...)
Sucks for me! but hopefully an unemployed craigslist tech can do it for me for cheap...
BTW... I don't think the poll is bias, it makes sense... it's about headgasket/headbolt failures in northstars and for what year... it's not a debate on if there's a problem... lol... that's no debate...
  #264 (permalink)
Old 09-11-09, 03:03 AM
Casino Cash: $1180
  #265 (permalink)
Old 09-11-09, 09:59 PM
Cadillac(s): deville dts
View blt2100's Photo Album
Casino Cash: $310
Hello all I am new here trying to keep my 2000 cadillac DTS running, I had the engine rebuilt in January 2008. Now when I drive on the highway it tries to run a little hotter than normal, so I took it back to the people that rebuilt the engine and they say they can't find anything wrong. so I paid the 435.00 for them to tell me that. everyone one I talked to says head gasket, so I took it to cadillac, from the symptoms they said HG, they did a block test on the car and said it turned out good, they also could not find any leaks 170.00 dollars later. I still smell radiator fluid and it still tries to run hot. Could it be a external leak? everyone is baffled, even the maker of the car is there another test we could have done. Please if anyone can help Nobody knows whats wrong. ;o ( HELP!!!!!!
  #266 (permalink)
Old 09-12-09, 04:26 PM
submariner409's Avatar
Casino Cash: $20619
How hot is "hot" ? The engine should run at close to 200 all day long, somewhat higher in traffic w/o a/c on (with a/c the fans run in slow all the time).
  #267 (permalink)
Old 09-13-09, 08:45 PM
Cadillac(s): Cadillac
View stutz427's Photo Album
Casino Cash: $395
Mine just went on a 99 SLS. For about 6 months I heard a little gurgling but thought it was just air in the system. Then one day it blew out all the coolant. I knew right then what it was and took it to Northstar performance to have Jake put in the studs. Just came back with it today for will let you know. By the way the gaskets went at 120,000 and I did everything to avoid it. I changed fluids, installed the ginger root, did WOT's at least once a month and preemptively changed the water pump. For me its just a poor design or materials from GM
  #268 (permalink)
Old 09-25-09, 10:14 AM
Cadillac(s): 2000 Deville
View kevlexus10's Photo Album
Casino Cash: $1275
2000 Deville DHS with 108k when the head gasket went south. Gathering info as we speak so I can drop the engine and get it back on the road. I miss my cadi
  #269 (permalink)
Old 10-16-09, 09:44 PM
View 4cambob's Photo Album
Casino Cash: $375
Unhappy Re: Northstar Headgasket/Bolt Failure? Please let us know
97 SLS 171,000 miles I put a used motor in it. Then timeserts at 185,000. Now I have 220,000 and I drive 60 miles to work and back. Saint Louis rush hour, bumper to bumper, 2 to 85 mph I70 traffic.
  #270 (permalink)
Old 10-16-09, 09:55 PM
Casino Cash: $375
The shop that put my timeserts in, said they did it block in car.
Tags: , , ,
failure, headgasket or bolt, northstar
