Go Back   Cadillac Owners Group > General Discussion > Cadillac Engine Technical Discussion > Northstar Performance and Technical Discussion
Northstar Performance and Technical Discussion Performance discussions relating to the Northstar System (intake, exhaust, cam, etc.).
Cadillac Forums: Northstar Headgasket/Bolt Failure? Please let us know
View Poll Results: Select one if you have had a problem with the headgasket the Northstar V8:
1993 10 2.62%
1994 29 7.61%
1995 9 2.36%
1996 22 5.77%
1997 83 21.78%
1998 90 23.62%
1999 90 23.62%
2000 26 6.82%
2001 16 4.20%
2002 13 3.41%
2003 5 1.31%
Multiple Choice Poll. Voters: 381. You may not vote on this poll
  #196 (permalink)
Old 02-23-09, 12:46 PM
Jesda's Avatar
Cadillac(s): 4.9 STS and stuff.
View Jesda's Photo Album
Casino Cash: $22138
Re: Northstar Headgasket/Bolt Failure? Please let us know
Bump.
Become a supporting member! Serious dog is serious.
  #197 (permalink)
Old 02-23-09, 03:23 PM
Cadillac(s): 1996 seville sts
View 70torino429's Photo Album
Casino Cash: $545
my 96 seville sts had them go at 79,000 miles, a shame such a nice car and it still looks gorgeous
  #198 (permalink)
Old 02-23-09, 08:39 PM
Cadillac(s): 90 Deville - 280k miles. 94 STS - 232k miles. (Blown)
View Dead STS's Photo Album
Casino Cash: $350
My 94 Seville STS began to go at around 143k miles.
I drove it until 232k miles. The only reason that I had to park it was because of the crossover gaskets failing (I think). Water was pouring from that side of the engine. The engine was still strong and ran smoothly and it did not smoke or run rough unless it was in limp home mode which happened a couple of times. I used to keep gallons of water and coolant in the trunk. Whenever it got hot I would pull over and wait a few minutes then fill it up and off I went.
I also used a lot of the Bars Leak powder. I would still race cars off the line while looking in the rear view at the steady stream of coolant pouring out.
I COULD NOT KILL THIS CAR. Beleive me, I tried. I would feed it more tap water and it would be fine for 50-100 miles. I estimate that the engine temperature exceeded 260 degrees and overheated two hundred + times. I still have it but have never had the time to fix it. The body and interior are in better condition than my 97 STS. It is at 162k miles with no engine problems.
  #199 (permalink)
Old 02-23-09, 08:47 PM
submariner409's Avatar
Casino Cash: $20619
Damn......drop the cradle, overhaul the top end, do an ECM mild tune, and drive it forever. Use Jake's head studs......it will never leak again. The car's worth the work..............
  #200 (permalink)
Old 02-24-09, 08:22 PM
Cadillac(s): Cadillac 08 SRX V6 AWD RADIANT BRONZE
View DELORES SCHNEIDER's Photo Album
Casino Cash: $1125
[/size]1998 ELDORADO ETC 144,000 miles
  #201 (permalink)
Old 02-26-09, 12:15 AM
Eldo1953's Avatar
Cadillac Owners Enthusiast
Cadillac(s): 53 Eldo, 54 CDV, 74 FWB 96 FWB (sold),1998 STS(sold), 03 ESV
View Eldo1953's Photo Album
Casino Cash: $10541
So you are saying you drove 90k miles on a blown HG??!
  #202 (permalink)
Old 03-01-09, 05:18 AM
Casino Cash: $350
Yes, my 94 STS went approximately 90,000 miles with a partially blown head gasket.
I left out the worst part of my Northstar blown hg/pulled head bolt story.
At around 141k miles the crankshaft got screwed up due to oil starvation caused by a piece of a gasket that got sucked up against the screen where the oil leaves the oil pan. This happened before I became a student of Bobinski the Northstar Guru. So when the engine was out I had no idea to tell my mechanic that we needed to Timesert the engine even though I had not experienced any problems with the cooling system. The overheating began shortly after crankshaft repair. This was my mechanics first and last Northstar.
Kelly
94 STS 232k miles
97 STS 162k miles
  #203 (permalink)
Old 03-01-09, 09:06 AM
Cadillac(s): 1998 Deville, (2) 2001 Devilles
View bigtone's Photo Album
Casino Cash: $7470
My 98 Deville developed head gasket problems at 81k miles. I found Number one cylinder leaking when I pressurized it with 100 psi air. The rear head bolts were a bit looser than the front, so I can assume that the threads were pulling. Timeserted the block, have about 1k miles on it so far with no problems. I did the entire job in the car, see my post under Northstar topics for pics.
  #204 (permalink)
Old 03-13-09, 03:53 AM
Cadillac(s): 1997 Cadillac Deville d'Elegance
View pinkbird53's Photo Album
Casino Cash: $360
180,000 - just this week diagnosed with the DREADED HEAD GASKET LEAK,
which may have been going on for some time now.
Over past year, I've had to keep topping off the coolant; and have had some external leaks - I've essentially had the entire cooling system replaced; water heater, radiator, heater hoses, radiator cap, overflow tank, thermostat and couplings, etc., etc.
Last weekend, the car overheated; first I got the 'check coolant level' notice - checked the coolant temp, which was 248. I immediately stopped, let it cool, then limped the car back to the repair shop I have been using. While limping back I got the 'engine overheated', 'idle engine', 'stop engine', and 'change engine oil' lights come on.
There are leaking seals at both ends of the metal tube that runs the coolant through the engine. The mechanic (and as far as I know, this is the FIRST TIME anyone did this test) - did find exhaust fumes in the coolant tank, indicating the DREADED HEAD GASKET LEAK. The dealership has also since confirmed these findings.
The repair will be about $3,000; and I have decided not to do it. I'll be buying a replacement car.
  #205 (permalink)
Old 03-13-09, 08:19 AM
Cadillac(s): 1998 Seville SLS
View str8bucs's Photo Album
Casino Cash: $555
1998 Seville SLS 86K
  #206 (permalink)
Old 03-15-09, 09:04 PM
View mike sts's Photo Album
Casino Cash: $1467
had a 94 STS first engine went at 55000 miles cracked head, they replaced it under warranty the second engine went 100,000 miles before it was leaking oil, fouling plugs with oil and coolant, coolant leak, not sure if head was cracked probably was junked the car
  #207 (permalink)
Old 03-16-09, 02:44 PM
mgturbo1's Avatar
Cadillac(s): 2003 STS
View mgturbo1's Photo Album
Casino Cash: $1850
Unhappy Re: Northstar Headgasket/Bolt Failure? Please let us know
1999 STS 71000mi
  #208 (permalink)
Old 03-16-09, 03:01 PM
N0DIH's Avatar
Cadillac Owners Master
Cadillac(s): 94 Fleetwood Brougham
View N0DIH's Photo Album
Casino Cash: $9087
Anyone junking one over a head gasket, let me know, I would like to get one to explore a LS1 swap....
  #209 (permalink)
Old 03-19-09, 05:18 PM
View mrlacy's Photo Album
Casino Cash: $1135
Had my 99 deville crap out with 127000 miles...it is in the shop as we speak getting put back together. Former GM Tech doing the work and said that these engines do this due to cadillac using a smaller head bolt since 94-95. He said GM knew about this problem during their test prototype northstars back as late as 87.
  #210 (permalink)
Old 03-22-09, 04:23 PM
View Shouse's Photo Album
Casino Cash: $580
I agree that the older n*'s aren't around to vote anymore.
We're probably all but extinct now.
Anyways, '94 STS. 135k. No problems yet (knocks on wood).
Not to say that this car hasn't had it's problems (it has) but no
HG yet or signs as I can tell. After Reading this thread I'm shakin in my boots though. I love to trade it off for a Challenger but cash flow is quite limited.
Quite the sticky situation.
Tags: , , ,
failure, headgasket or bolt, northstar
