| Re: How can I drive 1000 miles with a coolant leak? The water pump is at the back of the engine so it's something else leaking. Removing the cap is going to increase chances of the water pump cavitating and causing more problems. I'd verify where it's leaking. It may only take a couple of minutes with a boyscout knife to fix it. In a position similar to yours, I went to the nearest WalMart, bought a cheap toolset and a flashlight, tinkered up the problem, and had a nice trip home.
__________________ Don't mess with Binky Bear!
