Results 1 to 8 of 8
Thread: HELP ME!!!! What is the difference between ECON and Auto
    gotthavecaddi's Avatar
    gotthavecaddi is offline Cadillac Owners Member
    Automobile(s): 1994 Concorse
    Apr 2007
    bay area Cali
    6
    Red face HELP ME!!!! What is the difference between ECON and Auto
    I have a question what is the difference between econ and the auto setting? I have 1994 concours and I also want to know what the best setting to use when your car is having overheating problems. (to keep the engine cooler) Please Help Quick! Thanks!
    clarkz71's Avatar
    clarkz71 is offline Cadillac Owners Connoisseur
    Automobile(s): 2000 Eldorado ESC
    Mar 2006
    Fort Lauderdale, Florida
    53
    1,361
    Re: HELP ME!!!! What is the difference between ECON and Auto
    In econ mode there is no a/c compressor, in auto mode the compressor runs.
    You have to try both ways, the fans run in auto mode so it's possible
    it might run cooler. On the other hand the condensor is heating up as
    well. Could go either way. On a car with no problems, generally it will
    run cooler.
    caddydaddy's Avatar
    caddydaddy is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Escalade 6.0L 2WD, 2007 Jeep Grand Cherokee Limited CRD
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    If the car is having overheating problems, get that fixed before you drive it any more!
  5. #4
    MM STS's Avatar
    MM STS is offline Cadillac Owners Member
    Automobile(s): '00 STS Crimson Pearl/Blk, 18" STS wheels,Strut Tower Brace
    Aug 2007
    A Capitol Car
    52
    85
    Quote Originally Posted by caddydaddy View Post
    See posts on Head Gasket replacement usually caused by overheating. Mike
  6. #5
    69
    82,262
    Think of ECON as a compressor shut off switch. Other than using the compressor, the two modes operate exactly the same.
  7. #6
    Apr 2007
    bay area Cali
    6
    thanks it was driving me crazy not knowing what the difference between these 2 settings were
  8. #7
    Apr 2007
    bay area Cali
    6
    Wink Re: HELP ME!!!! What is the difference between ECON and Auto
    Thats obvious but with only 1 car this is not an option, need to get back and forth to work to get paid to buy parts so hubby can fix it. So was in search of the best quick fix. Unless you have a car I can use until then Just kidding
  9. #8
    codewize's Avatar
    codewize is offline Cadillac Owners Master
    Automobile(s): 91 Brougham d'Elegance / 95 Fleetwood Broug/ 01 DTS / 11 CTS Lux
    Apr 2005
    Upstate NY
    50
    6,920
    It's never a good time to give up a car when you have things to do, HOWEVER driving it with that condition is going to end up costing you twice as much to fix it in the end and may result in finding a new engine rather than repairing.
    Overheating a N* is nothing to fool with.
    And I don't know what hubby does for a living but if your dealing with a head gasket repair he's probably not going to be able to do the job.
    Ownership:
    91 Brougham d'Elegance 350
    95 Fleetwood Brougham
    01 Custom Deville DTS
    2011 CTS4 Luxury
    Memberships:
    National and regional Cadillac & LaSalle Club
    Proud Volunteer - Northstar Tuning Project
    Guinness World Records - Largest Cadillac Parade
  • You may not post replies
