Go Back   Cadillac Owners Group > General Discussion > Cadillac Engine Technical Discussion > Northstar Performance and Technical Discussion
Northstar Performance and Technical Discussion Performance discussions relating to the Northstar System (intake, exhaust, cam, etc.).
Cadillac Forums: Motor build for sand rail
Old 09-20-07, 01:23 PM
Cadillac(s): Cadillac
View mscatena's Photo Album
Casino Cash: $250
So I've done a few searches and have only come up with only one CURRENT after market builder
Cadillac Hot Rod Fabricators www.chrfab.com
are there any more???
I've recently pulled a motor from a junk yard and am currently cleaning the block & parts to get a better look at what the motors history is...
So far what I can tell is missing from the motor was
starter
coil packs
harness & ecu
alternator
also does anyone have info on using MSD coil packs & ECU's for a northstar engine?
I am just planning on a strip down rebuild to stock, maybe upgrade cams & intake from CHRF but nothing else.
any advise would be appreciated
Marc
  #2 (permalink)
Old 09-20-07, 02:57 PM
Cadillac(s): Member of Air Fuel Tuning (Cadillac Division)
View AJxtcman's Photo Album
Casino Cash: $13342
Re: Motor build for sand rail
starter
coil packs
harness & ecu
alternator
Marc
I have a very nice 00+ program that would work fine with a manual trans, but you would need a 00+ engine.
I am currently working on a 96 to 99 program with a manual trans. It is under constrution.
  #3 (permalink)
Old 09-20-07, 05:34 PM
Casino Cash: $250
is the program for a stock ecu?
  #4 (permalink)
Old 09-20-07, 10:37 PM
Casino Cash: $13342
YES
  #5 (permalink)
Old 09-20-07, 11:19 PM
View eldorado1's Photo Album
Casino Cash: $5065
what year is it? post a pic
  #6 (permalink)
Old 09-21-07, 06:54 PM
Casino Cash: $250
well the goal is to put the motor into this car
Revenge Silencer
http://www.revenge-racing.com/rr/silencer.html
  #7 (permalink)
Old 10-13-07, 03:05 AM
View jfreezn's Photo Album
Casino Cash: $250
A simple question about eliminating the fuel cut on my 94 ETC Northstar engine, currently on a test bench with factory wiring harness and ECM. I have wired a Passlock II into the PCM and the PCM is receiving the appropriate rmf signal of about 3VDC. Yet is refuses to run. I can feed it starting fluid and it fires and runs real clean, so I know the ignition is OK, but the fuel cut is still being enforced by the PCM.
Does ANYONE have a clue whether I can go into the PCM and bypass something? My early Corvette awaits this engine!
Jim in Phoenix
  #8 (permalink)
Old 10-13-07, 09:53 AM
Cadillac(s): 78 Seville,96 Aurora,Caddy with Olds engine,Olds with Caddy
View parts68's Photo Album
Casino Cash: $627
It sounds like the passkeyII still has the PCM injector pulse turned off.
I had same problem with a 94 3.4 swap and found the correct resistance
for the passkey module and wired a resistor into circuit of that value and then it fired.
The passkey II sends out a pulse width modulated signal to the PCM.
Kinda hard to duplicate with out a correctly functioning passkey module.
From what I remember there are 14 values of passkey.Take yours to the dealer
and ask them to read it for the value it needs.
  #9 (permalink)
Old 10-13-07, 11:35 AM
Casino Cash: $13342
Jim in Phoenix
This system works different. You wired in a Fuel Enable signal correct?
That will not work I think.
I will get back to this with the answer tonight.
  #10 (permalink)
Old 10-14-07, 09:58 AM
Cadillac(s): northstar ignited Big Block
View zbuickman's Photo Album
Casino Cash: $360
In order to enable the Injector circuit you need to supply The ECM with a 50Hz 50% dutycycle square wave.You can either buy or build a module to produce this signal or you can use the factory module with a resisto to reproduce this signal.... I suggest to buy or build one do a search on remote starters with PKII. Most remote starter manufacturers offer a PKII module
  #11 (permalink)
Old 10-15-07, 12:50 PM
Casino Cash: $250
Thanks for the quick replies, and yes to both of you. I have the passkey II module wired into the ignition and I have identified the correct resistance required to fire the passkey output, which I have metered (but not scoped) and it appears to be sending out a Pulse Width Modulated signal, which in the manual it just says to look for about 3 VDC. The signal comes and goes with the key cycle so it looks right. Still no fuel. My fuel pressure is sufficient that I am getting a return to the tank via the regulator, around 45 PSI on the header.
Side note: This thing really sounds great with the open headers, along side my house. I set fire to a decorative bush when i got too aggressive with the starting fluid!
Buickman: I have just ordered a remote start Passkey bypass from Commando at $25, plus shipping. I hope that does the trick.
Anymore thoughts, please chime in. I will update you when I get a test completed.
Jim in Phoenix
  #12 (permalink)
Old 10-16-07, 01:26 AM
Casino Cash: $360
That should do the trick for you
  #13 (permalink)
Old 10-16-07, 01:54 AM
Casino Cash: $13342
Jim in Phoenix
When it does not start let me know.
The car had a module (ipc) between the key and the PCM.
Other GM cars work different.
Tags: , , ,
build, motor, rail, sand
