Results 1 to 4 of 4
Thread: 2000 to 2004 or 5 Northstar information
    AJxtcman's Avatar
    AJxtcman is offline Cadillac Owners Connoisseur
    Automobile(s): The Northstar Tuner
    Apr 2007
    Rock Hill SC
    48
    2,755
    http://www.fiero.nl/forum/Forum2/HTML/080565.html
    jadcock's Avatar
    jadcock is offline Cadillac Owners Connoisseur
    Automobile(s): White Diamond 2001 STS
    Jan 2003
    North Carolina
    38
    1,317
    Re: 2000 to 2004 or 5 Northstar information
    AJ, is the "easy" way to tell a 2000-2003 engine apart from a 2004-2007 engine the main sight shield? That is, the 2000-2003 sight shield covers only the valley area and does NOT include the cam cover, but the 2004-2007 sight shield goes all the way down across the "front" (left) cam cover?
    AJxtcman's Avatar
    Apr 2007
    Rock Hill SC
    48
    2,755
    The 06 and 07 block are different.
    I see that I had listed 04 to 07 together. The cams must be the same, but the blocks and crank must be different.
    The crank sensor on 06 and 07's is mounted in the valley next to the starter.
  5. #4
    69
    82,281
    Copied to Tech Tips.
  • You may not post replies
