Go Back   Cadillac Owners Group > General Discussion > Cadillac Engine Technical Discussion > Northstar Performance and Technical Discussion
Northstar Performance and Technical Discussion Performance discussions relating to the Northstar System (intake, exhaust, cam, etc.).
Cadillac Forums: Mystery Grind in Transmission, Engine, Where?
Old 05-23-07, 05:11 PM
Cadillac(s): 1994 Eldorado Touring Coupe
View ScoobyRoo's Photo Album
Casino Cash: $250
I recently purchased a 1994 ETC with about 130k on it for 1800. The car looks wonderful but has a few flaws, one being when put into gear after its sat a bit (few hours) it will make a grinding noise up front for a brief period of time then quiet up. If its shut off then started up just after it wont make a peep, only after its sat a bit will it. Ive noticed that if I have my foot resting on the brake pedal I can feel it vibrating with the grind BUT it will grind without my foot on the pedal either way. Anyone else experience this? Ive been told in another thread that it may be the a/c clutch but I want to make sure. If the clutch pack was slipping would it make this noise as well? Tends to sound like grinding the gears on a manual but slightly softer.
  #2 (permalink)
Old 05-24-07, 10:50 PM
codewize's Avatar
Cadillac Owners Master
Cadillac(s): 1989 STS / 2001 DTS / 2002 DTS
View codewize's Photo Album
Casino Cash: $14430
Re: Mystery Grind in Transmission, Engine, Where?
How about sounding like rolling a coffee can full of marbles? Is that close to what it sounds like. Every time I've had an AC compressor go bad, that was the way I described it. Almost sounds like a water pump rattle when they have a bad bearing.
Ownership:
89 STS (1 of 1893) - FOR SALE
02 Blue Onyx DTS
01 DTS:
Custom installed Volant CAI
Custom PCM
Body color engine components
Cruiser Alloy wheels
EBC brakes
Eibach springs
Corsa exhaust
Sportwing Spoiler
Semi-custom interior
Custom quad Hi-Beams
Future Plans: More interior work.
Memberships:
National and regional Cadillac & LaSalle Club
Proud Volunteer - Northstar Tuning Project
  #3 (permalink)
Old 05-25-07, 02:42 PM
Casino Cash: $250
Is there any way to figure out for sure if its that or not?
  #4 (permalink)
Old 05-26-07, 12:31 AM
codewize's Avatar
Casino Cash: $14430
Remove the serpentine belt and spin all the accessories by hand. the bad one will feel rough or be difficult to turn. They should all spin freely. If they do, you have other problems.
  #5 (permalink)
Old 05-27-07, 09:41 AM
Casino Cash: $250
I've noticed that the car wont make the noise as long as you keep the rpms low when it starts up, but the moment you bring it anything above a rolling idle it makes the noise.
  #6 (permalink)
Old 05-27-07, 06:24 PM
codewize's Avatar
Casino Cash: $14430
Does the car have to be moving for it to make the noise?
  #7 (permalink)
Old 05-28-07, 11:53 AM
Casino Cash: $250
Yes.
  #8 (permalink)
Old 05-29-07, 09:02 PM
codewize's Avatar
Casino Cash: $14430
If the car has to be moving I'm guessing it's a wheel bearing. Pretty common failure. My transmission all but fell apart inside and made no noise at all until the very end when I was revving over 4500 RPM.
I'd be looking at the wheel bearings.
  #9 (permalink)
Old 05-30-07, 06:49 PM
Casino Cash: $250
I can roll around all day just letting the idle pull the car along like I said, it will only make the noise when I put my foot on the accelerator.
  #10 (permalink)
Old 05-30-07, 06:53 PM
99Classillac's Avatar
Cadillac Owners Enthusiast
Cadillac(s): Ex-99 Deville owner, Now-04 DTS owner, and a 07 ZX6R pilot
View 99Classillac's Photo Album
Casino Cash: $707
It could be your traction control engaging also. My 99 deville does it. I think my wheel speed sensors are bad. Dry or wet outside, if I'm stopped and try to accelerate even the slightest, the traction control engages and makes a horrible grinding sound. It goes away after a couple seconds.
  #11 (permalink)
Old 05-30-07, 10:04 PM
codewize's Avatar
Casino Cash: $14430
Hmm interesting. Could it be CV joints? Does it click when you make a corner? It's definitely drive-line related but I don't think it's the trans. Could still be wheel bearing but that TC or ABS problem seems realistic also. If it's a wheel speed sensor you'll have a code.
  #12 (permalink)
Old 05-31-07, 04:33 PM
Casino Cash: $250
I hope its not a tranny problem, if it is I'm just selling the thing at a loss or not. I don't even want to get into a problem like that. Replacing the oil pan gasket and main seal is going to be enough as it is. When I get the time I'm going to pull more codes out of it, I got a set of ism's awhile ago and they describe being able to go MUCH further into the diagnostics than I originally did. I wish I could record the noise :P
  #13 (permalink)
Old 07-28-07, 05:21 PM
Cadillac(s): 1997 Eldorado
View Zorb750's Photo Album
Casino Cash: $1180
Check for a loose hub. They can move slightly if worn and loose, while the engine torque is applied. I have had this sort of grind myself.
Tags: , , ,
engine, grind, mystery, transmission
