  Follow CadillacOwners on Twitter
Go Back   Cadillac Owners Group > General Discussion > Cadillac Engine Technical Discussion > Northstar Performance and Technical Discussion
Northstar Performance and Technical Discussion Performance discussions relating to the Northstar System (intake, exhaust, cam, etc.).
Cadillac Forums: Engine Overheat Brake Caliper??
Old 05-21-07, 11:39 AM
Cadillac(s): '64 Cpe Deville, '94 Concour
View C170B's Photo Album
Casino Cash: $335
Could it be possible that a slightly dragging rear brake caliper cause an engine overheat?
Has it ever been reported on this forum?
Driving in Ozark hills (we call them Mountains 1550 ft) I experienced " Engine Coolant Hot " warning twice.
N* is a very tough engine and I hate to blame headgaskets at every overheat.
I have come to the belief that all of todays' cars are engineered and built with very little if any cooling reserve.
So my question really is Could a combination of Speed 60MPH, big HILLS plus a slightly dragging L rear brake caliper cause the N* to overheat? Are there any real life examples to lend credence to my situation?
regards
  #2 (permalink)
Old 05-21-07, 12:53 PM
jadcock's Avatar
Cadillac(s): White Diamond 2001 STS
View jadcock's Photo Album
Casino Cash: $325
Re: Engine Overheat Brake Caliper??
No -- any cooling system in good shape should have the capacity to handle that. If the engine overheated under those severe conditions, it could be that your radiator is partially plugged, your thermostat is not opening fully, you have a cooling system hose collapsing, etc. Also don't overlook the coolant temperature sensor/switch. It could be faulty.
Summer mountain driving brings arduous conditions, but these cars (as most cars are) are tested under severe desert heat under 120 degree ambient temperatures. Your car should have plenty of cooling system capacity to handle 80s and 90s in the Ozarks.
  #3 (permalink)
Old 05-21-07, 08:21 PM
View Ranger's Photo Album
Casino Cash: $28206
A dragging brake will cause extra load on the engine, but it should not be enough to cause the engine to overheat.
Todays cooling systems are not what they used to be. They are smaller with less capacity, but as Jadcock said, they are tested under worse conditions than you mentioned and should stand up to it if well maintained. Have you ever cleaned the bugs and dirt out of the condenser?
  #4 (permalink)
Old 05-21-07, 08:59 PM
dkozloski's Avatar
Cold Soaked
Cadillac(s): 2006 STS AWD, '95 Ford Ranger
View dkozloski's Photo Album
Casino Cash: $14827
GM cooling systems are engineered to cool the engine on a 100 degree day at 100MPH with a 100MPH following wind. I saw this parameter published years ago. Maybe it's different today.
Don't mess with Binky Bear!
  #5 (permalink)
Old 05-21-07, 09:53 PM
JimHare's Avatar
Cadillac(s): 01 Eldo ETC, 02 Deville
View JimHare's Photo Album
Casino Cash: $1396
..and I'd be concerned about the "slightly dragging rear caliper" while you're at it. One does not want red-hot components glowing away in close proximity to the fuel tank....
"For a successful technology, reality must take precedence over public relations, for Nature cannot be fooled." - Richard P. Feynman
Tags: , , ,
brake, caliper, engine, overheat
attach your bluetooth cell phone to onstar
flash wax for your cadillac
cadillac key wraps
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
custom floor mats | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods | air suspension kits | air suspension parts | air ride suspension | hyundai genesis forum
