Hello, I recently replaced the head gaskets on my 2000 STS northstar. The car started fine, drove for 50 miles, died, and no re-start. Well it spits and sputters, but hardly runs. No codes, replaced crank sensors, relearned crank sensors. Cylinder leak down test shows good. Good crank rpm signal, good cam sensor signal. Fuel pressure and spark are good. I rechecked the timing marks, and everything is lined up perfectly still. I cannot believe its noit setting a code, I can communicate with all modules including PCM fine.
I've been a Cadillac Tech for 4 years, but this vehicle is making me pull my hair out, any suggestions are welcomed. Thank you so much.
Brian
BrianC974@yahoo.com
