| Northstar Performance and Technical Discussion Performance discussions relating to the Northstar System (intake, exhaust, cam, etc.). | Cadillac Forums: Help! Stuck piston in n* I need help!
04-30-07, 12:13 AM
| | Cadillac Owners Member Cadillac(s): 1994 Eldorado Touring Coupe, Polo Edition, '03 CTS | | Join Date: Jul 2005 Location: CA Age: 60 | | Help! Stuck piston in n* I need help! I took my '94 Eldorado touring coupe to dealer serv. becaouse all of a sudden it started smoking really bad, white smoke. They did a compresion check and it was OK 170 lbs. So they thought it was a piston the was stuck. They did a piston decarb twice and checked #8 cylinder with bore scope-- looked good. But when they road tested it again #8 plug still fouling and started smoking again. So I got a plug spacer to help the smoking. Does anyone know any tricks to unstick the piston? This is my baby I love this car only 80K miles and it's one of the few Polo additions, really stands out in a crowd. PLEASE HELP!!!!!! Thanks ahead of time to anyone who can help. Kay |
04-30-07, 12:54 AM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: Help! Stuck piston in n* I need help! Kay,
You've been a member for 2 years. Surely you have heard of the WOT treatment? Go to the Technical Archives at the top left of this page and read up on "oil Consumption" and "Occasional Full-Throttle Acceleration Is Good For Your Engine". What you are describing is stuck piston rings. This procedure should free them up. |
04-30-07, 08:55 AM
| | Cadillac Owners Connoisseur | | Join Date: Feb 2004 Location: FL | | | Re: Help! Stuck piston in n* I need help! Since it is only one cylinder, it's more likely to be a valve seal. In a northstar, when they leak, they really leak. |
04-30-07, 12:33 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: Help! Stuck piston in n* I need help! Good point. |
04-30-07, 04:42 PM
|  | If it won't run, chrome it..... Cadillac(s): 2002 Cadillac F55 STS/53000mi., 2004 Ford F150 Super cab 4x4 | | Join Date: Feb 2006 Location: Maryland upper Eastern Shore Age: 70 | | | Re: Help! Stuck piston in n* I need help! White smoke usually signals coolant in a cylinder, doesn't it? Blue smoke is oil, and black smoke is rich (fuel) mixture. |
04-30-07, 05:20 PM
| | Cadillac Owners Connoisseur | | Join Date: Feb 2004 Location: FL | | | Re: Help! Stuck piston in n* I need help! Quote:
Originally Posted by submariner409 White smoke usually signals coolant in a cylinder, doesn't it? Blue smoke is oil, and black smoke is rich (fuel) mixture. | Normally yes..... but it's easy to get the colors confused if you've never seen it before. Since the plugs are getting fouled, it is almost certainly an oil issue. |
04-30-07, 05:46 PM
|  | Cold Soaked Cadillac(s): 2006 STS AWD, '95 Ford Ranger | | Join Date: Jul 2004 Location: Fairbanks, Ak Age: 70 | | | Re: Help! Stuck piston in n* I need help! If the valve guide seals are leaking the engine will put out a puff of blue smoke after engine braking or idling. Under power the exhaust is clear. Leaking rings make smoke under power.
__________________ Don't mess with Binky Bear! |
04-30-07, 08:26 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: Help! Stuck piston in n* I need help! White "smoke" can also be unburnt fuel vapor (excessively rich). |
04-30-07, 09:53 PM
| | Cadillac Owners Connoisseur Cadillac(s): Member of Air Fuel Tuning (Cadillac Division) | | Join Date: Apr 2007 Location: Inside The Northstar PCM Age: 41 | | | Re: Help! Stuck piston in n* I need help! This is comical.
First it is a 94 and the instake is not plastic.
EGR passage? That would be a very good guess!
PCV system would be the #1 guess if it had a PLASTIC manifold because the pcv drops oil into the intake above #8 runner.
If the plug is oil fouled then I would look at the EGR passage. You will need to remove the intake to clean it out. You may need to remove the cross over and clean it out also. TSB?
ZMAX is now a recomended ring cleaner from GM |
05-01-07, 10:42 PM
| | Cadillac Owners Member Cadillac(s): 1994 Eldorado Touring Coupe, Polo Edition, '03 CTS | | Join Date: Jul 2005 Location: CA Age: 60 | | | Re: Help! Stuck piston in n* I need help! What's up? No one seems to agree on anything. Let me clarify a few things. Realy heavy cloud of white smoke, not like when it's burning rich. Smokes under power but more when braking and idling. Even after the engine is turned off a small wisp of smoke keeps coming out for a minute or so. The spacer in the #8 plug did not stop any of the smoke. So guys, now what? Thanks, Kay |
05-02-07, 01:36 AM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: Help! Stuck piston in n* I need help! Does the smoke smell like oil or fuel? |
05-03-07, 11:49 AM
| | Cadillac Owners Connoisseur Cadillac(s): Sedan de Ville, CTS | | Join Date: Mar 2007 Location: San Antonio, Tx | | | Re: Help! Stuck piston in n* I need help! Hope you have a wallet full of money or a real honest mechanic or both. Northstars are sometimes not cheap to fix. |
05-03-07, 09:58 PM
|  | Cold Soaked Cadillac(s): 2006 STS AWD, '95 Ford Ranger | | Join Date: Jul 2004 Location: Fairbanks, Ak Age: 70 | | | Re: Help! Stuck piston in n* I need help! Have somebody hold a piece of cloth over a tailpipe while you goose it a couple of times. See what shows up on the cloth. A blind man ought to be able to tell whats coming out and making the smoke. | | Cadillac Discussion Tools | | |
Censor is ON | | | |
