where to buy torque plate for honing block?
Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Northstar Engines and System Technical Discussion Discussion, where to buy torque plate for honing block? in Cadillac Engine Discussion; Does any one know where or maybe have a torque plate that I could buy for an N*? I know ...
    dgarrett is offline Cadillac Owners Member
    May 2005
    21
    Does any one know where or maybe have a torque plate that I could buy for an N*? I know some think it is not necessary, but I just have to have one. The block is a 2004.
    dkozloski's Avatar
    dkozloski is online now Cadillac Owners 10000+ Posts
    Jul 2004
    Fairbanks, Ak
    28,313
    Re: where to buy torque plate for honing block?
    Quote Originally Posted by dgarrett View Post
    I always made my own torque plates. It's an easy job for any well equipped machine shop.
    Don't mess with Binky Bear!
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,156
    dkoz hit the magic nail....."well equipped machine shop". Break out your VISA card and go shopping. It (torque plate) had better be pretty thick and substantial...after all, you're trying to simulate the pull of cylinder head bolt torque as you bore/hone.
    BodybyFisher Guest
    Can you explain why you are honing the block? We have seen the cross hatch remain on the cylinders after many many miles, this is the first time I have heard a NS being honed.. Do you have a damaged cylinder?
    zonie77 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 ETC,97 STS
    Sep 2003
    Arizona
    3,531
    dgarrett, you have all of our curiosity piqued! What are you doing and why?????
    Feb 2006
    57,156
    OMG....I hope he's not going to "bore and stroke" it !!! N*'s have a quench clearance about as thick as a sheet of toilet paper. Valve to piston clearance is zippo, also.......
    BodybyFisher Guest
    Quote Originally Posted by submariner409 View Post
    WOW, I did not know what quench clearance meant and I found this on a Corvette forum, Mike
    http://forums.corvetteforum.com/show...19&forum_id=48
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,313
    The tight quench clearance is the reason behind the infamous Northstar "carbon rap". When the clearance goes negative from the buildup of carbon the result is the noise.
    BodybyFisher Guest
    Quote Originally Posted by dkozloski View Post
    I asked this question once, can a buildup of carbon causing the carbon rap, cause the bolts to pull from the physical force?
    Feb 2006
    57,156
    YES. Can also break things like cylinder heads, pistons, rods, etc., but that's an extreme situation....
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,313
    The carbon is soft enough that as it builds gradually it crushes and makes clearance for itself. What does happen is that when the engine is stopped it cools off and the clearance goes negative. Crank the engine up cold and now the piston whams the head, making a lot of noise until the carbon breaks up or the engine warms.
    A side note is that as an alloy engine warms the power output drops because the engine expands and compression ratio drops. The L-88 cast iron 427 Chevy was dimensionally the same engine as the alloy ZL-1 but put out more power because it didn't expand like the alloy engine even though it was a hell of a lot heavier.
    May 2005
    21
    No not stroking it, and has 93mm bore. It's going in a road race track car (C4 corvette)
    12:1 compression
    CP Pistons with 1mm, 1.2mm and 2.8mm low tension rings
    eagle rods
    stock crank 2003
    ported 2003 block
    2005 heads with modified oil passages, VVT removed
    custom intake and electronic fuel system
    Kiesler TK0-600 tranny
    Alan Johnson Flywheel, bell housing and clutch
    The ring pack is why I need to hone it right.
    Pistons will be .007 in the hole, head gasket is .040, should be good for 8500rpm+. This includes rod stretch, and all other clearances.
    Its not a street car, tear downs will happen often.
    BodybyFisher Guest
    I would love to hear this engine run, post links to videos or mp3s if you can... when you run it... I assem the block is time-serted for tear downs? Please post your tear down experience with the time-serts... Thanks
  16. #14
    Feb 2006
    57,156
    Nominal .045 piston clearance should be fine. Stock springs?
  17. #15
    May 2005
    21
    I have 180 lb'ers from Alan Johnson.
    This guy has a thread in this forum that last over 2 and 1/2 years describing his N* build for his Fiero. This is the best source of information about N* performance builds that I have seen on the net!
    http://www.fiero.nl/forum/Forum2/HTML/044924.html
  18. Remove Advertisements
