NorthStar .. fathered by the ALLANTE ....
Results 1 to 12 of 12
Northstar Engines and System Technical Discussion Discussion, NorthStar .. fathered by the ALLANTE .... in Cadillac Engine Discussion; what a precious car the Allante is. IT brought to you the now famous NORTHSTAR as the 1992 Indy 500 ...
    Stealth's Avatar
    Stealth is offline Cadillac Owners Enthusiast
    Automobile(s): Is one enough ?
    Jun 2003
    So CA
    646
    as the 1992 Indy 500 Pace car driven by Bobby Unser
    and here is the history of the NortStar, its problems and its solutions,
    its failures, its leaks, etc ...
    come look. most likely, if you are driving a Cadi or a Olds, you got one.
    http://www.cadillacforums.com/forums...lante-buy.html
    http://www.cadillacforums.com/forums...allante-forum/
    CadillacSTS42005's Avatar
    CadillacSTS42005 is offline Banned
    Automobile(s): 2005 STS4 1SG: GM Acc Lights, Corsa, Platnium Grille, Volant
    Oct 2005
    15,987
    Re: NorthStar .. fathered by the ALLANTE ....
    92 there was no N*
    it was 93 model year that the N* was dropped into the Allante...
    Stealth's Avatar
    Jun 2003
    So CA
    646
    clarifying ...
    the EVENT WAS the 1992 Indy 500,
    the car was the 1993 pre-production Allante.
    the Pace Cars
    the 1st cars in the world to run with a NorthStar.
    the Pace cars, built while 1992 production was on-going.
    but they are 1993 models.
    the same design was also used by Olds, they called it the AURORA.
    NorthStar = Aurora
    Oct 2005
    15,987
    exactly why i said 93 MODELS had the N* only
    i was doing this as to clarify
    JimHare's Avatar
    JimHare is offline Cadillac Owners Connoisseur
    Automobile(s): 01 Eldo ETC, 02 Deville SOLD!
    May 2004
    Salem, NJ
    63
    1,815
    Quote Originally Posted by Stealth View Post
    clarifying ...
    the Pace Cars
    NorthStar = Aurora
    If your thinking astronomically, Northstar = Polaris.
    dkozloski's Avatar
    dkozloski is online now Cadillac Owners 10000+ Posts
    Jul 2004
    Fairbanks, Ak
    28,215
    Quote Originally Posted by JimHare View Post
    What the heck do snow machines have to do with it?
    Don't mess with Binky Bear!
    JimHare's Avatar
    May 2004
    Salem, NJ
    63
    1,815
    Your snow blower has a Northstar?...kewl...
    Stealth's Avatar
    Jun 2003
    So CA
    646
    maybe not everyone is aware, but the NorthStar and the Olds Aurora engine are essentially the same engine.
    the engine was developed as a joint venture and the agreement was to
    allow Cadillac introduce it. Olds followed Cadillac about two years later.
    one design group, one project, one budget - two releases.
    "1992 -
    The Northstar engine was introduced as the first step in what eventually
    became the Northstar System. The 4.6-liter, 32-valve V8 was first installed in
    the Allanté and became available in other front-wheel-drive Cadillacs a year
    later and as the Oldmobile Aurora the following year. "
    "... the Northstar V8 has evolved over the years. In 1994, the first Northstar V8 (L37, 1993)) was joined by a second version (LD8, 1994)) with a different cam profile that lowered peak horsepower slightly to 270 hp but increased torque output in the lower rpm range for improved throttle response and quick acceleration.
    In 1994, a Northstar V8 was introduced in the Oldsmobile Aurora. The L47 4.0L V8 was essentially the same engine as the larger 4.6L V8 but with a smaller bore size (87mm vs. 93mm). The L47 4.0L V8 was rated at 250 horsepower.
    In 1995, the power rating of the L37 4.6L V8 (VIN 9) was bumped up slightly to 300 hp, and the LD8 4.6L V8 (VIN Y) was upped to 275 hp.
    The two basic versions of the 4.6L V8 (275 and 300 hp) are still being used in model year 2003, and there are no plans to replace this engine in the immediate future. So it looks like the Northstar V8 will continue to enjoy a long production run.
    GM recently unveiled its Northstar XV12 concept engine that is physically about the same size as the existing V8 but is capable of producing up to 750 horsepower! The engine uses cylinder deactivation technology to keep fuel economy manageable, but there are no productions plans yet for this exotic power plant."
    Stealth's Avatar
    Jun 2003
    So CA
    646
    can someone enlighten me as to what the "LINKBACK" at the very end
    of this screen is for? is is set fo rtype "Refbacks".
    i read the description and i am simply wondering how one would trigger the LINKBACK and the purpose (aside just being informed it happened).
    the linkback for this thread is the FORUM ITSELF? i think ... !
    Posted by: < Northstar Performance and Technical Discussion - Cadillac Owners >
    z06bigbird is offline Cadillac Owners Connoisseur
    Automobile(s): Sedan de Ville, CTS
    Mar 2007
    San Antonio, Tx
    4,769
    "1992 -
    Why does XLR-V have a 4.4 northstar instead of a 4.6? No one has been able to answer this for me.
    Ed
    Cadillacboy's Avatar
    Cadillacboy is offline Cadillac Owners Connoisseur
    Automobile(s): 1996 Cadillac Fleetwood Brougham
    Dec 2003
    36
    4,388
    Basicly 4.4 Northstar is supercharged that are used in V Series whereas 4.6 is "normal" neither supercharge nor turbo .
    I don't know why 4.6 doesn't have those power boosters .I assume 4.6 is already using its limit .
    Feb 2004
    FL
    2,250
    Quote Originally Posted by z06bigbird View Post
    Ed
    They reduced the bore size. This did 2 things - created a stronger/more rigid block, and increased detonation resistance due to decreased distance for the flame front to travel.
    Although I think the "official" word off the GM website is to "increase fuel economy"
    [valley girl]As if![/valley girl]
  15. Remove Advertisements
