Failure to start
Results 1 to 2 of 2
Northstar Engines and System Technical Discussion Discussion, Failure to start in Cadillac Engine Discussion; '94 Seville. Bought this car at auction, so no history is known. Would take over a minute of cranking to ...
    Harry Yarnell is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 XLR, '96 eldo,'95 eldo,' 89 eldo,'78 eldo,'11CTS-V
    Dec 2004
    perryman, MD
    73
    846
    Failure to start
    '94 Seville. Bought this car at auction, so no history is known. Would take over a minute of cranking to get it to fire when cold. Afterward, it would fire almost instantly.
    Now it won't start. Period. It coughs and sputters out the exhaust and throttle body, like the timing's way off. Ether doesn't help. I suspect crank sensors. Fuel pressure is around 30#, engine off. Any other suggestions?
    68
    82,048
    Re: Failure to start
    30 psi is rather low fuel pressure. It should be up around 45 as I recall. Any Codes?
