Need a little starting help?
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 20
Northstar Engines and System Technical Discussion Discussion, Need a little starting help? in Cadillac Engine Discussion; Hi all my name is david, I just bought my son a 97 deville i think the starter may be ...
    davidr is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Jan 2007
    4
    I just bought my son a 97 deville i think the starter may be bad but here are the probs.I got the car from a lady that drove it into some high water it stalled and she tried to restart it .she said it tried to turn over a couple of time then nada so she got it pulled home and let it dry out.her husband tried to start it a couple of weeks later and still nothing a new battery and still nothing.So here it is 6 mths later and we have the car.It eill be my sons first car but we need to get it running.Do you folks have any suggestions?Could it be the starter shorted out?If so how and where is it located it would be the first spot i guess to check.It does click when trying to turn it over,any help would be appreciated.
    david
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,216
    Re: Need a little starting help?
    Quote Originally Posted by davidr View Post
    david
    How high's the water Momma? Over the floor? Over the hood? Over the roof? Did it stop Kerchunk?
    Don't mess with Binky Bear!
    Cad tech's Avatar
    Cad tech is offline Cadillac Owners Fanatic
    Automobile(s): 03 STS, 97 STS, 58 Eldo
    Jan 2007
    275
    Um pull spark plugs and release the water in cyclinder probally hydrolocked...the with the plugs out crank it over the rods may be bent...
    Jan 2007
    4
    She said it was not over the hood but it was up to the front bumper.I pulled the plugs they looked fine it still would not crank though.I was just wondering if it might have blown a fuse or shorted the starter or solinoid?I cant even find the d#$%n starter on this thing.
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,216
    The starter is under the intake manifold. It's about an hour job to get it out and back in.
    68
    81,928
    That sounds like awful deep water. I wonder if she didn't hydrolock it. Starter, as mentioned is high & dry under the intake. Does it make any noise at all when you turn the key?
    Jan 2007
    4
    No noise other than the clicking.I already pulled the plugs and it still would not turn i did this last week.I am wondering about mayby a relay or something?
    david
    68
    81,928
    Pull the plugs again. Put a wrench on the crankshaft dampener bolt, and see if you can spin the engine at all.
    Hope you didn't pay too much for it.
    Cad tech's Avatar
    Jan 2007
    275
    the clicking most likely is the starter trying to turn over, try this first so we can all go shwewwwwwww then post back....
    Jan 2007
    4
    Well it does look like it is locked up.I could not turn the thing at all.No oil leaks.so mayby i should try a rebuild?What do you folks think?I cant belive i did not try to turn the thing over i just figured the starter was shot!!!rack one up for dumb rass.Any thoughts folks?
    david
    Cad tech's Avatar
    Jan 2007
    275
    well get those spark plugs out shoot some air in the cyclinders to clean the water out....get some WD-40 and coat those cyclinders good, let it sit overnight, then bet your biggest breaker bar out and start turning it get it so it is easy then use the starter as an assist, clean out those cyclinders before you reinstall the plugs....say a couple hail marys, sprinkle some holy water on it and pray no rods bent......
    I_Finally_Have_A_Cad is offline Cadillac Owners Fanatic
    Automobile(s): 1998 Cadillac Deville
    Jun 2006
    Mid-Michigan
    33
    194
    I can't remember where I heard it, but I want to say that there is some penetrating oil that is marketed for or does a good job at this exact thing. It uses the same process as the one tech described. Maybe it was here that I heard about it. There was a thread about a poor guy whos engine was hydrolocked and some butt-head laughed at him and the same thing happened to him.
    zonie77 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 ETC,97 STS
    Sep 2003
    Arizona
    3,531
    If the engine hydrolocked it probably bent the connecting rods.
    Did you drain the oil? If it hasn't been changed it should have water in it. If it's very clean it probably was changed. Hydrolocking locks the engine while the water is in the cylinders, once you get the water out it should spin. If it was left for months with the water in it the cylinders are probably rusty. The easiest fix would be a used engine.
  16. #14
    Sep 2003
    Arizona
    3,531
    A hydrolocked engine is covered under comprehensive! My son did it to his Jeep. His insc replaced the short block.
  17. #15
    68
    81,928
    Quote Originally Posted by zonie77 View Post
    That would be my vote it indeed it is hydrolocked.
  18. Remove Advertisements
