fuel pump 96 eldo
Results 1 to 4 of 4
Northstar Engines and System Technical Discussion Discussion, fuel pump 96 eldo in Cadillac Engine Discussion; is there any unforeseen problems w/replacing my fuel pump?what type of gasket sealer will i use?i know corrosion can be ...
    eldonova is offline Cadillac Owners Member
    Mar 2004
    14
    fuel pump 96 eldo
    is there any unforeseen problems w/replacing my fuel pump?what type of gasket sealer will i use?i know corrosion can be a factor ,any safeguards?
    thanx d.s.
    formulacarracerjim's Avatar
    formulacarracerjim is offline Cadillac Owners Member
    Mar 2004
    Pittsburgh Pa
    56
    11
    Re: fuel pump 96 eldo
    No sealers needed as there is an o-ring that should come w/any decent replacement pump. BLOW away ALL the crap on the top of the tank after removed and before opening tank. Also soak the locking ring with solvent and then blow the loose solvent away. Keep the crap outta there! Watch gasolione fumes! They are FAR more explosive then you would ever believe. Jim
    joeveto's Avatar
    joeveto is offline Cadillac Owners Member
    Feb 2004
    Cuyahoga Falls, OH
    94
    Quote Originally Posted by formulacarracerjim
    I agree. Plan on putting the bong down for at least an hour.
    Also, change out the fuel filter at the same time. It's never a bad idea. I would also suggest going with an AC Delco unit. They tend to be a lot better than the other brands which run a few bucks cheaper.
    Mar 2004
    14
    Thanx,it was a piece of cake .pretty cool blow molded tank.no rusty crap.
  7. Remove Advertisements
