Coolant Level
Results 1 to 15 of 15
Northstar Engines and System Technical Discussion Discussion, Coolant Level in Cadillac Engine Discussion; If the check coolant level message displays on the information center how low is the coolant, how much needs to ...
    STS127 is offline Cadillac Owners Fanatic
    Automobile(s): 96 STS
    Dec 2006
    Massachusetts
    112
    Coolant Level
    If the check coolant level message displays on the information center how low is the coolant, how much needs to be added. It occured while I was driving today and drove it around another time and did not pop up. The time it happend though the engine was very cold and the message came on right when I pulled out of the school parking lot. Would the cold weather have anything to do with it? Its in the mid 20's today so it is fairly cold out.
    68
    81,920
    Re: Coolant Level
    I'm not exactly sure when it is tripped, but it is before it gets critical. You still have coolant in the tank. Just bring up to about 2" from the fill neck. Then keep an eye on it to figure out where it is going.
    Flynn is offline Cadillac Owners Member
    Automobile(s): Black 2002 DTS - Just like (the late) Vito Spatafore's
    Jan 2007
    Littleton, CO
    23
    Re: Coolant Level
    My car has a slight coolant leak at the radiator. (bottom hose I think, haven't crawled under to pinpoint it yet) Anyway, the "check coolant level" shows up on the DIC about every two months or so. I have a 12 oz plastic bottle I fill halfway with DexCool, the other half with distilled water, and pour the whole thing in the surge tank. Not real fancy, but it works.
    Dec 2006
    Massachusetts
    112
    Re: Coolant Level
    How much does a 96 STS take-15 quarts?
    benshizzle is offline Cadillac Owners Member
    Automobile(s): 2000 Deville DTS
    Oct 2006
    St.paul, MN
    32
    33
    Re: Coolant Level
    I get this message also. It says check coolant level when its cold outside (below 20F). I popped the hood and it WAS low but after driving for 2 minutes the message went away. I pulled over into a parking lot and checked again and the coolant was at the right level. I think coolant might contract and expand depending on the temperature. this happened in my 2000 DTS a couple of times after sitting outside in cold weather over night.
    68
    81,920
    Re: Coolant Level
    If coolant concentration from cold temps is turning on the CHECK COOLANT LEVEL message, then the level is too low to start with.
    Dec 2006
    Massachusetts
    112
    Re: Coolant Level
    Just bought some Dex-Cool and hope to change coolant this week. I'm figuring level is low and don't know when the last time it was changed(Have maintance records so I'll check them) so I think just changing it all together would be better than adding some.
    Cad tech's Avatar
    Cad tech is offline Cadillac Owners Fanatic
    Automobile(s): 03 STS, 97 STS, 58 Eldo
    Jan 2007
    275
    Re: Coolant Level
    Quote Originally Posted by STS127 View Post
    12.5 quarts
    Dec 2006
    Massachusetts
    112
    Re: Coolant Level
    ^^ Yeah I think you're right. Transmission is 15 quarts right.
    Cad tech's Avatar
    Jan 2007
    275
    Re: Coolant Level
    Transaxle
    Drain and Refill, Requires Drain Plug Removal
    10.4 liters
    11.0 quarts
    Overhaul
    12.0 liters
    12.6 quarts
    Dry
    14.2 liters
    15.0 quarts
    detroit99sts is offline Cadillac Owners Fanatic
    May 2005
    242
    Re: Coolant Level
    My coolant level is low also. how often is it recommended to completely change (drain & fill) the cooling system? Ive had the same coolant for 2 years now. Should I drain & fill? Is it safe to flush the system?
    68
    81,920
    Re: Coolant Level
    Your '99 has orange Dex-Cool so once every 5 years. 2 years for green coolant.
    bigmike750's Avatar
    bigmike750 is offline Cadillac Owners Member
    Automobile(s): 2001 Cadillac Deville
    Nov 2006
    Tucson, AZ
    39
    Re: Coolant Level
    dont forget to add the tablets to the dex cool....and smash them up before you put them in
  16. #14
    68
    81,920
    Re: Coolant Level
    No need to crush them in a Northstar. Just pop them in the radiator hose whole. DO NOT put them in the surge tank.
  17. #15
    Mountie's Avatar
    Mountie is offline Cadillac Owners Enthusiast
    Automobile(s): '93 STS (sold), now looking for a CTS Wagon soon!!
    Jul 2005
    Bradenton, Fl
    62
    502
    Re: Coolant Level
    When I replaced my Northstar, I upgraded my oil cooler to about twice the size ( same brand - same bolt install) .....Totally dry, I put in 10 quarts oil in the engine.
  18. Remove Advertisements
