pics of the progress
Results 1 to 7 of 7
Northstar Engines and System Technical Discussion Discussion, pics of the progress in Cadillac Engine Discussion; well a couple of you know about my cracked block and me rebuilding another block the rust in the bore ...
    smooththg6969's Avatar
    smooththg6969 is offline Cadillac Owners Fanatic
    Automobile(s): 99 Seville SLS( parts) ,98 sts
    Feb 2003
    121
    well a couple of you know about my cracked block and me rebuilding another block the rust in the bore etc.. well I finally started putting the block together day by day so heres a couple of pics of my progress
    pistion ring thread
    http://www.cadillacforums.com/forums...ion-rings.html
    cracked block thread
    http://www.cadillacforums.com/forums...ked-block.html
    I inserted a pistion in the bore with the rust after I cleaned the bore and honed it with the berry hone it moves smoothley that is the only bore I honed. Im hopeing not to loose more than 10 psi even though the FSM says 140-170 psi is the acceptable range now my only fear is it not starting after I get it back together but i ill take my time getting it back together and hopfully it will run with out problems.
    thu's Avatar
    thu
    thu is offline Cadillac Owners Connoisseur
    Automobile(s): 2003 STS w/BoseNav, 1993 Deville, 1985 Deville
    Jul 2003
    Wyoming
    1,089
    Re: pics of the progress
    Nice Pics.
    Please send more pics as you progress!
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,241
    Your cylinder rust is a non-factor. You're going to have to find something else to worry about. It's minimal. Good luck!
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,209
    In second and last pics, sure is easy to see the crank position sensor reluctor wheel......Don't sweat the small rust patch....build it clean, use cam assembly lube, figure a way to pressurize the oil system just before startup, drive it like you stole it.........Do you know anything about porting and polishing? Now would be a good time to clean up the insides of the headers and crossover pipe.........DON'T MESS WITH THE HEADS !!!!!
    Cad tech's Avatar
    Cad tech is offline Cadillac Owners Fanatic
    Automobile(s): 03 STS, 97 STS, 58 Eldo
    Jan 2007
    275
    just dont hook up connectors on ICM and crank this will pressurize the oil system...
    Feb 2003
    121
    Here Are some more pics most of the engine. it is together now just little things now but I just ran into a problem you can check that out in the post titled am I screwed
    bigmike750's Avatar
    bigmike750 is offline Cadillac Owners Member
    Automobile(s): 2001 Cadillac Deville
    Nov 2006
    Tucson, AZ
    39
    Man that looks like a night mare wanna do mine next
  10. Remove Advertisements
