1996 Deville PCM 0717
Results 1 to 2 of 2
Northstar Engines and System Technical Discussion Discussion, 1996 Deville PCM 0717 in Cadillac Engine Discussion; i have a deville d'elegance with 80000 on it. it runs great. i am getting the service transmission, pcm 0717, ...
    tandersonoo7 is offline Cadillac Owners Member
    Feb 2004
    1
    Question1996 Deville PCM 0717
    i have a deville d'elegance with 80000 on it. it runs great. i am getting the service transmission, pcm 0717, speed sensor code. the transmission shifts smoothly and i can't notice anything. how serious is pcm 0717? thanks in advance for the info.
    ta
    formulacarracerjim's Avatar
    formulacarracerjim is offline Cadillac Owners Member
    Mar 2004
    Pittsburgh Pa
    56
    11
    Re: 1996 Deville PCM 0717
    Transmission input shaft speed sensor code locks out Torque converter clutch and all trans adaptives. Fuzzy Logic. In Pittsburgh you will not pass our emission program w/o repairing it. Trans remove/install w/ teardown of unit.
    P.S. We do that here! Jim Locke
