Can't track down these error codes
Results 1 to 2 of 2
Northstar Engines and System Technical Discussion Discussion, Can't track down these error codes in Cadillac Engine Discussion; I had a link for error codes and it's now dead. I have read a bunch of posts regarding codes, ...
    jguelcher is offline Cadillac Owners Member
    Oct 2003
    52
    I had a link for error codes and it's now dead. I have read a bunch of posts regarding codes, but can not find any that seem to match mine. In fact, I saw some that start with P or PO but none like mine. They are as follows:
    IP 1552
    PC 0603
    TC 0027
    TC 0073
    PZ 1558
    I had just a few hours ago disconnected the battery for a few minutes. These codes all show up since then. Thanks for any help you can provide.
    BeelzeBob's Avatar
    Dec 2002
    Fort Lauderdale, Florida
    52
    9,577
    Re: Can't track down these error codes
    Quote Originally Posted by jguelcher
    IP 1552
    PC 0603
    TC 0027
    TC 0073
    PZ 1558
    Did the codes say "current" or "history". You cannot eliminate or erase or clear the codes by disconnecting the battery. That will make them go to history but it will not erase them. If the codes were current and you disconnected the battery it just made them history.
    IP 1552...loss of keepalive memory...battery disconnect....IPC
    PC 0603...PCM....keep alive memory reset....battery disconnect.
    TC 0027...left front wheel speed sensor..traction control
    TC 0073....PCM-TCS interface link fault
    PZ 1558...PZM eeprom check sum error
    You are causing the first two codes by disconnecting the battery...
    Fix the wheel speed sensor.....
    The other codes may be due to the wheel speed sensor. Fix the wheel speed sensor and re-evaluate.
