02 Deville Sudden Stall
Page 1 of 3 123 LastLast
Results 1 to 15 of 40
Northstar Engines and System Technical Discussion Discussion, 02 Deville Sudden Stall in Cadillac Engine Discussion; I recently bought a 2002 Deville. I have experienced twice now a sudden engine stall. Once when coming to a ...
    danielscherbing is offline Cadillac Owners Member
    Automobile(s): 2002 Cadillac Deville
    Dec 2006
    Minneapolis, MN
    22
    I recently bought a 2002 Deville. I have experienced twice now a sudden engine stall. Once when coming to a stop at a light, I noticed warning lights but didn't hear the motor quit. It fired back up immediately. The second time, I was idling after pulling out of the garage. Engine quit suddenely. It fired back up and has not happened again.
    Also, I have noticed a very small flutter in the headlights when driving. It is almost as if they shut off completely for s split second and then are back on. I don't see it happeneing with anything else and I have already replaced the bulbs with no change.
    And third, I do notice a rough idle when cold, the motor seems to hop a little. I have tried the injector/fuel cleaners with no change.
    The car has approx 61000 miles. Let me know what you think! Thanks!
    FrankT's Avatar
    FrankT is offline Cadillac Owners Enthusiast
    Automobile(s): 99 STS
    Mar 2004
    Michigan
    61
    700
    Re: 02 Deville Sudden Stall
    Sounds like the ever famous 00 -02 Crankshaft Position Sensors (CKP)'s Reolace both sensors.
    Try pulling codes, you may or may not have some.
    The sensors are common problems in these years.
    Frank
    dp102288's Avatar
    dp102288 is offline Cadillac Owners Connoisseur
    Apr 2006
    North Brunswick, NJ
    28
    4,236
    There is a writeup on how to change the sensors in the somewhere on the forum. A search will point you in the right direction.
    codewize's Avatar
    codewize is offline Cadillac Owners Master
    Automobile(s): 91 Brougham d'Elegance / 95 Fleetwood Broug/ 01 DTS / 11 CTS Lux
    Apr 2005
    Upstate NY
    50
    6,920
    Yup, again.
    Ownership:
    91 Brougham d'Elegance 350
    95 Fleetwood Brougham
    01 Custom Deville DTS
    2011 CTS4 Luxury
    Memberships:
    National and regional Cadillac & LaSalle Club
    Proud Volunteer - Northstar Tuning Project
    Guinness World Records - Largest Cadillac Parade
    Submariner409's Avatar
    Submariner409 is online now If it won't run, chrome it
    Feb 2006
    MD Eastern Shore, Kent Island
    56,826
    This is just a SWAG (scientific wild-ass guess), but the headlight "flutter" may be due to the microsecond shutdown caused by the crankshaft position sensor(s) triggering an intermittent "engine off" signal. We would like to find out if that problem disappears after you replace the CKP sensors 1 AND 2.
    dp102288's Avatar
    Apr 2006
    North Brunswick, NJ
    28
    4,236
    ^^ Very interesting with the shutoff signal...
    turbojimmy's Avatar
    turbojimmy is offline Cadillac Owners Connoisseur
    Automobile(s): 1994 Fleetwood 60" Stretch; '07 Avalanche, '95 Nighthawk
    Apr 2004
    New Jersey
    3,963
    The headlights on my '01 will dim suddenly at random, but only for a split second. It corresponds with some other clicking sound at the back of the car. I guess it's some kind of big electrical draw. They don't shut off, but I can see them dim very briefly if I'm sitting in traffic and the lights are reflecting off of someone's car. I haven't noticed it while driving but I'm sure it happens.
    Also, I'd guess your crankshaft position sensor(s) are bad (and not related to the headlights).
    Jim
    Feb 2006
    56,826
    ^^ Turbojimmy......Could your headlight dimming be caused by the ride height compressor cycling? If so, there MAY be an air leak somewhere back there......A flood rebuild may have a loose hose nipple or something.....
    turbojimmy's Avatar
    Apr 2004
    New Jersey
    3,963
    Quote Originally Posted by submariner409 View Post
    I'm not sure. I replaced the compressor when I rebuilt the car. I've never tried to pinpoint the noise. Today I was putting air in the left rear tire (slow leak) and I heard the clicking. Not sure what it is. It's always 6 clicks, kind of like an on/off, on/off, on/off kind of thing. Until today it sounded like it was in my front driver's side door.
    Jim
    dp102288's Avatar
    Apr 2006
    North Brunswick, NJ
    28
    4,236
    Interesting idea about the leaky air compressor!
    Feb 2006
    56,826
    ^^ This is one for Sherlock Holmes. Let us know when you find the bug!
    FrankT's Avatar
    Mar 2004
    Michigan
    61
    700
    Quote Originally Posted by turbojimmy View Post
    Jim
    Turbojimmy,
    I think it's the AIR pump active self-test. The algorithm for the AIR pump is such that it will perform an active test at very low speeds and light load conditions. When the AIR algo kicks in to perform the test it will run the pump for a few seconds ON/OFF about three times, then watches to see if the H02S switch lean.
    The AIR Pump has an in-rush current of about 55 amps, then draws a steady 25-30 amps. So you are correct that its a big electrical draw, but a normal one.
    If you want to verify if it's indeed the AIR Pump, pull the AIR Pump fuse for a few days and see if your headlights stop the dimming. If it does then we found your strange anomaly, replace the fuse and clear DTC P0410.
    Not all cars have the AIR system, but in 01 I think that all Devills have it.
    Happy New Year,
    Frank
    69
    82,268
    FWIW, I have noticed the same momentary dimming of my headlights on my '02 SLS & my '03 DHS. I don't think it is related to the AIR pump as I notice it when the engine is up to operating temperature so the AIR pump should not be cycling on at that point. I believe whatever it is, is normal since both cars have experienced it and I have heard others mention it.
  16. #14
    FrankT's Avatar
    Mar 2004
    Michigan
    61
    700
    Ranger,
    You are correct the AIR Pump runs when the engine is cold to help accerlaerate the catlyst warm up.
    However, the PCM runs two tests to diagnose the AIR system: Passive, and Active. The active test runs when the engine is warm. See below copy and past from FSM.
    Active Tests
    • The engine is running.
    • The engine speed is more than 600 RPM.
    • The throttle is steady.
    • The engine load is less than 80 percent .
    • The system voltage is more than 10.5 volts.
    • The MAF is less than 35 g/s.
    • The fuel system is in closed-loop operation.
    • The EVAP purge is active.
    • The ECT is more than 68°C (154°F).
    Happy New Year Ranger
  17. #15
    turbojimmy's Avatar
    Apr 2004
    New Jersey
    3,963
    Makes sense to me. I'm not really worried about it, just curious. So what's the clicking? The relay? The clicking is in the back.
    Jim
  18. Remove Advertisements
