Best Exhaust Upgrade for a 96 STS.
Results 1 to 5 of 5
Northstar Engines and System Technical Discussion Discussion, Best Exhaust Upgrade for a 96 STS. in Cadillac Engine Discussion; I was thinking of upgrading my exhaust in the time to come and was curious on which would be the ...
    STS127 is offline Cadillac Owners Fanatic
    Automobile(s): 96 STS
    Dec 2006
    Massachusetts
    112
    I was thinking of upgrading my exhaust in the time to come and was curious on which would be the best. I found that Dynomax Thrush mufflers have basically the same dimension size as the stocks, 20in. length, 9-10in. width and 4-5in. thickness with the 2in. offset/center pipes. Any others worth considering?
    1997BlackETC's Avatar
    1997BlackETC is offline Cadillac Owners Connoisseur
    Automobile(s): 2012 Mercedes E63 Amg Station Wagon
    Apr 2006
    Florida
    58
    1,348
    Re: Best Exhaust Upgrade for a 96 STS.
    I've heard the Corsa systems are real nice for the STS if you can find one, I've got an Eldorado so I am out of luck as far as the Corsas go. Does not really bother me much though as I kind of value my piece and quit especially in a luxury car.
    MrEr1c's Avatar
    MrEr1c is offline Cadillac Owners Fanatic
    Nov 2004
    277
    The corsa system will not fit a '96 without some custom adjustments.
    But the corsa does use 2.5 inch piping so i would recommend have a good shop (mandrel bends only) make you a nice catback with piping and some decent mufflers that you think sound good.
    I would go with a high-flow cat, and only two mufflers if not one. Or if possible, keep your stock exhaust and just wled in an electric cutout. Have the cutout after the last o2 sensor and if possible, before any cats/mufflers.
    CadillacSTS42005's Avatar
    CadillacSTS42005 is offline Banned
    Automobile(s): 2005 STS4 1SG: GM Acc Lights, Corsa, Platnium Grille, Volant
    Oct 2005
    15,987
    dp102288's Avatar
    dp102288 is offline Cadillac Owners Connoisseur
    Apr 2006
    North Brunswick, NJ
    28
    4,236
  8. Remove Advertisements
