Reduced new engine power during breakin period?
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 21
Northstar Engines and System Technical Discussion Discussion, Reduced new engine power during breakin period? in Cadillac Engine Discussion; I have read of ECMs using the hour meter and or odometer as part of the ECM's measurment of engine ...
    snopro is offline Cadillac Owners Member
    Nov 2004
    11
    QuestionReduced new engine power during breakin period?
    I have read of ECMs using the hour meter and or odometer as part of the ECM's measurment of engine usage to control engine and trans performance(spark advance, fuel delivery, rpm, shift points, etc)to limit power (engine loading) during a pre-defined breakin period.
    What I am interested in is what types of control does Caddy use on their engines for this purpose, how much does it reduce engine output, how long (hours and or miles) is the control active and does it deactivate gradually or at a set point?
    mtflight's Avatar
    mtflight is offline Cadillac Owners Connoisseur
    Automobile(s): 1999 White Diamond ETC
    Jan 2005
    Dallas, TX
    2,538
    Re: Reduced new engine power during breakin period?
    Quote Originally Posted by snopro View Post
    From what I've read on here, there is not much done for engine breakin. The car's are run for 15 minutes or so. The tolerances are so small that the long breakin process is a thing of the past.
    The most important things are to properly bed the brakes. Driving fast during the brake breakin period is not recommended because it could result in deposits that harm the rotors and cause an uneven wear and inefficient braking power.
    Look this up in the STS and STSV XLRV sections... that's where I read it.
    Nov 2004
    11
    That is the beauty of the ECM doing it for us.....there is no owner/driver consideration required.........the manufacturer presets the breakin maximum engine conditions and the ECM uses this programing until a certain hours or miles of operation is reached....floor it and you get 280 hp instead of 320...maybe you notice, maybe not....either way once the ECM can then go to its normal operation and rated performance outputs without fear of poor breakin by the operator driver damaging the engine.....I have driven vehicles where there is a night and day performance difference between 200 miles and 4000 miles...
    ....I am just curious how its done by Caddy, how much is it reduced, and at what point should we be at normal rated operation.
    Anybody with some engine programing experience out there?
    Feb 2004
    FL
    2,250
    There is nothing acting as you describe on a cadillac. What would be the benefit?
    mtflight's Avatar
    Jan 2005
    Dallas, TX
    2,538
    There is a rev limiter when the transaxle is in P. It won't allow drop-shifting from neutral, and the PCM will cut back torque when necessary (as part of traction control). I haven't heard of anything special during engine break-in.
    68
    81,917
    I have never heard of anything like that.
    dp102288's Avatar
    dp102288 is offline Cadillac Owners Connoisseur
    Apr 2006
    North Brunswick, NJ
    28
    4,236
    ^^ Me either, would be a good idea though...
    Feb 2004
    FL
    2,250
    Quote Originally Posted by dp102288 View Post
    again, what would be the point?
    caddydaddy's Avatar
    caddydaddy is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Escalade 6.0L 2WD, 2007 Jeep Grand Cherokee Limited CRD
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    So you don't drag race off the dealer lot? LOL, I don't know!
    dp102288's Avatar
    Apr 2006
    North Brunswick, NJ
    28
    4,236
    Oh I think it would be good to ensure a good break-in. The engine would try to stop any potential damage to itself by the driver.
    I guess that way some problems (like rings not setting well) could be lessened.
    Feb 2004
    FL
    2,250
    You need to vary the RPM for proper break in. According to several GM break in procedures, you NEED to do some wide open throttle runs.
    http://books.google.com/books?id=XGx...oaMUFdxTxc74EM
    -Drive with varying speeds and loads (typical city driving) for 30 miles
    -5 or 6 medium throttle runs
    -5 or 6 wide open throttle runs
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,215
    My new CTS had 30 miles showing on it when I took delivery. I drove it home 360 miles like I stole it. It's run perfectly ever since. Using the OLM it averages about 11,000 miles between oil changes and I've never had to add a drop. Break-in is a non-issue in my opinion.
    Don't mess with Binky Bear!
    dp102288's Avatar
    Apr 2006
    North Brunswick, NJ
    28
    4,236
    ^^ @ the previous 2: Wow...I didn't know it was called for to WOT it! Guess reduced power would mess things up more then.
  16. #14
    stevebuick23's Avatar
    stevebuick23 is offline Cadillac Owners Fanatic
    Automobile(s): 1997 STS, 2000 L67 Regal Beagle
    Oct 2006
    27
    287
    Quote Originally Posted by dkozloski View Post
    11,000 miles between oil changes? C'mon....
  17. #15
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,215
    Quote Originally Posted by stevebuick23 View Post
    Read up on the OLM system in the technical section of the forum. This system was developed as a BS eliminator by GM and they stand behind it 100%. You can't argue with success. The OLM for the transmission works the same way.
  18. Remove Advertisements
