bottom pulley wabbles
Results 1 to 11 of 11
Northstar Engines and System Technical Discussion Discussion, bottom pulley wabbles in Cadillac Engine Discussion; On the pass side of the car, the very bottom pulley looks as if its loose, is this the water ...
    CognLac is offline Cadillac Owners Member
    Sep 2003
    Mesa, AZ
    37
    89
    On the pass side of the car, the very bottom pulley looks as if its loose, is this the water pump pulley? and it sometimes makes a noise as if it needs some WD-40 has anyone seen a pulley fall off or become loose and start to wabble?
    capn's Avatar
    capn is offline Cadillac Owners Fanatic
    Automobile(s): 94 Eldorado ETC
    Feb 2004
    NC PM me if your around here
    216
    Re: bottom pulley wabbles
    if its the big one thats the crank pulley and thats not a good one to have come off, it drives all the acc. power steering and all that (i might add that a 94 ETC is very hard to drive with no PS) but make sure its tightend down correctly
    El Dobro's Avatar
    El Dobro is offline Cadillac Owners Connoisseur
    Sep 2003
    1,471
    Don't drive the car around until you have it checked. If that pulley lets loose, you can be in for some very expensive repairs. Have it checked by a garage right away.
    BeelzeBob's Avatar
    Dec 2002
    Fort Lauderdale, Florida
    52
    9,577
    Quote Originally Posted by CognLac
    The very bottom, large pulley is the crankshaft harmonic damper/drive pulley. It is attached to the end of the engines crankshaft.
    The front surface of the crankshaft harmonic damper pulley is an "as cast" surface so it is not uncommon for it to "look" like it is wobbling slightly. I seriously doubt that it really is as problems with that pulley are very rare. The key is to look carefully at the belt grooves in the drive pulley. Those are machined separately from the front surface of the pulley...so....the grooves that the belt runs in should run straight with no wobble... Check the belt grooves only for runout and ignore any runout in any of the other surfaces.
    The damper is held onto the end of the crank by a very large bolt that clamps the damper, the oil pump drive sleeve and the cam chain sprockets together. It is highly unlikely that the damper is loose as if it is loose the engine will instantly loose oil pressure....
    There is the unlikely, but possible. situation where the damper pulley is failing in that the elastomeric joint that joins the outer ring/pulley to the center hub is failed and the outer ring is slipping off. This is usually pretty obvious as there will be a distinct offsett between the center hub and the outer ring and the belt grooves will be wobbling and out of line causing the belt to run crocked.
    It is pretty easy to inspect the condition of the damper, actually, by removing the right front tire and the plastic splash panel at the rear of the wheel well. The damper/pulley is directly in front of you and easily visible there.
    Sep 2003
    Mesa, AZ
    37
    89
    AFter taking a better look at it, the pulley looks fine the noise seems to be comming from the place where you fill up the pwr steering fluid, or even inside the engine, my buddy said like a cam bearing, if it has one, but it does sound like a bearing going out of somekind, same kind of werid kind of high pitch squeel, but its not constant, seems to be worse at startup
    any advice would be greatfull. i probably will not have the time to get in there for another week,
    Lawrence's Avatar
    Lawrence is offline Cadillac Owners Fanatic
    Oct 2003
    Ohio
    334
    Your probably right in that it's the PS pump. bbob has a post on that somewere, you'll have to do a search. Something about an o-ring between the resovior and the pump. Also take the belt off and by hand spin all the pulleys and tensioners, etc. to listen for a rough one. You can go by feel to as it won't make the same noise by hand. They should all spin free, smooth and quiet.
    BeelzeBob's Avatar
    Dec 2002
    52
    9,577
    Take a piece of 3/8 rubber hose, stick one end in your ear and use the other end like a stethascope to listen around the engine to find the noise.
    Not likely that it is a "cam bearing".... With 4 cams and 21 cam bearing caps I don't think so....
    Likely it is a bearing in a pulley in one of the idler pulleys in the accessory drive or possibly the AC compressor hub bearing or even the belt squeeling due to a slight missalignment.
    First thing to to do isolate it to the accessory drive is to loosen the belt tensioner with the engine running so that the belt slips and the accessory drive stops. If the noise stops then it is in the belt drive or an accessory. Use a 1/2 inch breaker bar to unload the tensioner in the 1/2 inch square drive lug. Once the spring loaded tensioner is unloaded the belt will usually stop moving. If the noise stops then at least you have it isolate to an accessory.
    Listen with the hose at the idler pulley and the idler on the belt tensioner. Both have sealed bearings that could be getting dry. They can be greased or replaced easily.
    Look at the power steering mounting bracket and make sure that the locating tab on the bottom of the bracket is seated against the machined front face of the block. There is a locating tab one the bracket that must be seated against the block for proper alignment and no belt squeel at the power steering pulley.
    If it is the AC hub bearing that can be replaced in the car by pulling the compressor hub/clutch/pulley off and replacing the bearing or the entire hub assembly. You can do this in the car without discharging the AC.
    Listen around with the hose to isolate the noise source...that is the most important thing to do.
    Sep 2003
    Mesa, AZ
    37
    89
    I will try to listen more closely tonight after work, if it is a pulley bearing should I have at least till next commission check before all hell breaks loose?
    thanks
    Lawrence's Avatar
    Oct 2003
    Ohio
    334
    Monthly check?
    You'll likely have time, but be prepared for the unexpected.
    CadiJeff's Avatar
    CadiJeff is offline Cadillac Owners Connoisseur
    Automobile(s): 1981 CoupeDeville, 2 1990 Eldorados, 1994ETC ,1992STS
    Feb 2004
    Nerk,Ohio
    36
    1,072
    Check the power steering fluid level, I know it sounds obvious but most of the pwr/strng noises that I have seen in my cadi's were due to low fluid, including a similar noise situation in my 88 seville.
    BeelzeBob's Avatar
    Dec 2002
    52
    9,577
    If the squeel you describe is a bearing running dry in one of the idler pulleys or something then I would recommend getting it fixed ASAP....if it is already making noise it is close to failing and spitting the belt off. At the moment all you need is a new bearing/pulley assembly...you might need a new belt and ????? if you wait and it fails completely...not to mention the tow and agony of walking home...
  14. Remove Advertisements
