XLR's N* VVT rumble on startup and engine light.
Results 1 to 3 of 3
Northstar Engines and System Technical Discussion Discussion, XLR's N* VVT rumble on startup and engine light. in Cadillac Engine Discussion; out of 5 cold starts in 1 my engine makes a shutter noise for a few seconds and then dissapears, ...
    KvH
    KvH is offline Cadillac Owners Member
    Automobile(s): XLR, CTS
    Dec 2006
    Bahrain
    13
    out of 5 cold starts in 1 my engine makes a shutter noise for a few seconds and then dissapears, the engine light comes on due to this after a few days and at my dealer I got the impression they are guessing the problem...
    Sometimes I hear a squilling sound as well that dissapeared after good WOT sessions.
    The engine is widely used like it should be and runs very smooth, I tried octane boosters, carburator/injector cleaners etc. but no changes so far,
    only a white water vapour smoke sometimes with the cleaner.
    Anyone a thought?
    GreenMachine's Avatar
    GreenMachine is offline Cadillac Owners Fanatic
    Automobile(s): 1998 Cadillac Deville
    Jun 2005
    Amherst (Buffalo), New York
    29
    484
    Re: XLR's N* VVT rumble on startup and engine light.
    Don't try anymore of the additive stuff. If you can get a hold of an OBDII scanner (most car parts stores scan your car for codes free) that would send you in the right direction as far as "codes" and might actually point you right to your problem.
    The squilling could be a belt.
    Could you elaborate more on the shutter sound? Where does it sound like its coming from?
    dp102288's Avatar
    dp102288 is offline Cadillac Owners Connoisseur
    Apr 2006
    North Brunswick, NJ
    28
    4,236
    ^^ I agree. Post the codes if you can get a hold of them. In the Tech Tips sub-forum there are directions on how to pull the codes directly from the car, but I am not sure if it the same with an XLR.
