CODES-I'm New-Check Engine light
Results 1 to 5 of 5
Northstar Engines and System Technical Discussion Discussion, CODES-I'm New-Check Engine light in Cadillac Engine Discussion; I bought a 97 deville with 8,000 miles and yesterday a 96 with 123,000. On the 96 I got theses ...
    bunker570 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Dec 2006
    23
    On the 96 I got theses codes PC0603,PC1406,history?,IP1552 and AC1348. Also i get an info message that oil level is low,(it is not) and sometimes an emmission message.
    Please help the new "kid" on the block use the codes.
    68
    81,917
    Re: CODES-I'm New-Check Engine light
    Code definitions:
    http://myweb.accessus.net/~090/dtcobd2.html
    If the oil level is not low and you get the message, you probably have a bad sensor, but before you replace it, pull the connector and clean it with Brakleen. It may be just a bad connection from an oil leak.
    dp102288's Avatar
    dp102288 is offline Cadillac Owners Connoisseur
    Apr 2006
    North Brunswick, NJ
    28
    4,236
    Damn, 2 Caddys in one day?!
    Dec 2006
    23
    I bought the 97 a few months ago. A real dream car. Very low miles. Just got the 96 which has a perfect body,interior, and was well maintained.I do need a front wheel alignment, slight to the left, but only paid $3200 for it
    dp102288's Avatar
    Apr 2006
    North Brunswick, NJ
    28
    4,236
    ^^ Oh...sounds more normal!
  8. Remove Advertisements
