Annoying Tranny Whine
Results 1 to 5 of 5
Northstar Engines and System Technical Discussion Discussion, Annoying Tranny Whine in Cadillac Engine Discussion; I own a 98 Concours with 184000 on it. Its a beautiful ride with no problems. I have noticed that ...
    fristim is offline Cadillac Owners Fanatic
    Automobile(s): 98 Concours 212,000 orginal motor,trans
    Jul 2003
    Springfield Mo
    37
    160
    I own a 98 Concours with 184000 on it. Its a beautiful ride with no problems. I have noticed that with the onset of colder temps, when the car is cold I get a hydraulic whine almost like the sound of a power steering pump thats low on fluid. The tranny only whines at the shift points, and last for maybe 2 secs. I dont get the whine when it shifts into overdrive. I dont know if I may just need to add fluid or what. Any suggestions would be great. No shift problems and it stops when the temp gets to about 150. I also dont have the problem in the summer time.
    davesdeville's Avatar
    davesdeville is offline Banned
    Automobile(s): 1995 ETC, 75 Deville, Cad500 powered 73 Apollo, 94 Mark VIII
    Aug 2003
    Albuquerque, NM
    29
    7,971
    Re: Annoying Tranny Whine
    You mean you haven't checked the fluid?
    dp102288's Avatar
    dp102288 is offline Cadillac Owners Connoisseur
    Apr 2006
    North Brunswick, NJ
    28
    4,236
    Check the fluid. Out 89 Regal used to whine when driving it. We took it to Aamco and for $40 they added some fluid to our car! Why didn't I check that?!
    Jul 2003
    Springfield Mo
    37
    160
    Actually, I change the fluid about every 20,000 myself. The fluid level is normal when cold and hot.
    dp102288's Avatar
    Apr 2006
    North Brunswick, NJ
    28
    4,236
    ^^ 20K? They are usually good for 100K changes, but that's pretty good. I hear its not the easiest job to do, so that why they say 100K!
    I say if it isn't the fluid, spend $40 and let Aamco diagnosis it. Don't let them BS you, but hear what they will say. You will know what really needs to be fixed after you talk to them.
  8. Remove Advertisements
