Results 1 to 7 of 7
Thread: check engine light
    Apr 2003
    68
    14
    check engine light
    My check engine light keeps coming on...1994 sedan deville
    Dec 2002
    Fort Lauderdale, Florida
    52
    9,577
    Re: check engine light
    Quote Originally Posted by frontierman
    OK....there is a trouble code in the onbaord diagnostics that is turning on the light.
    Simultaneously press and hold the OFF and WARMER buttons on the climate control panel with the key on until the onboard diagnostics activates. Read off the codes and see what they are. Post back for more info.
    Impossible to say why the light is on without knowing what codes are stored.
    Apr 2003
    68
    14
    Here are the codes:
    code po 13 history
    code po 44 history
    no ipc codes
    noacp
    no sir
    notcs
    so21 history
    so 60 history
    pcm?
    That is all I got..Can you help?
    Mike
  5. #4
    Apr 2003
    68
    14
    Here are the codes:
    code po 13 history
    code po 44 history
    no ipc codes
    noacp
    no sir
    notcs
    so21 history
    so 60 history
    pcm?
    Mike
  6. #5
    mcowden is offline Cadillac Owners Connoisseur
    Jun 2003
    1,164
    You posted the same thing three separate times. Go read your other post for answers.
    Mike
  7. #6
    Apr 2003
    68
    14
    Yeah, I realized that..I have read the posts..Do you have anything to ad as far as a solution to the problem.
  8. #7
    Jun 2003
    1,164
    Well evidently you didn't read much because I posted suggestions in your duplicate posting. Hope you get it fixed.
    Mike
  • You may not post replies
