Oil Change
Results 1 to 6 of 6
Northstar Engines and System Technical Discussion Discussion, Oil Change in Cadillac Engine Discussion; Well, I did my first oil change on the new motor in my car. Wow! It is really scary how ...
    chazglenn3's Avatar
    chazglenn3 is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 White Diamond STS N* 1SF RWD ACC/HUD
    Sep 2004
    Tacoma, WA
    54
    1,966
    Oil Change
    Well, I did my first oil change on the new motor in my car. Wow! It is really scary how much metal new engines can make while they are breaking in! The magnetic drain plug had a little "afro". That was at 500 miles, I think I will change the oil and filter again in 500 miles.
    dp102288's Avatar
    dp102288 is offline Cadillac Owners Connoisseur
    Apr 2006
    North Brunswick, NJ
    28
    4,236
    Re: Oil Change
    Yeah, I have heard that the best thing to do with any new engine is an oil change at 500, 1,000, 2,000, 3,000, and then the normal amount of miles. May be overkill, but maybe spending $50 now will save a repair later!
    chazglenn3's Avatar
    Sep 2004
    Tacoma, WA
    54
    1,966
    Re: Oil Change
    Yeah, that is probably the interval that I will use. I agree oil and filters are MUCH cheaper than engines.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,151
    Re: Oil Change
    If you want a real eye-opener, using a lathe or hacksaw, cut the "top" off the old oil filter. Pull out the paper element and carefully cut around the top and bottom plates. Remember that oil flows in from the "outside" of the element, then flows out through the center tube. Take the pleated paper, in several sections, and squeeze it dry in a vise, accordion style. Pull the paper flat and determine which was the "in" side and the "out" side. (You'll know by the junk on one side). The amount of aluminum flakes and sealant blobs, on the "in" side of the first filter after overhaul, will amaze you. Next change, do the same. There should be nearly nothing in that filter, or any subsequent ones. If, a year or so down the road, you begin to get either bearing metal or aluminum flakes in a filter, suspect a coming problem. 90% of the "dirt" created by an engine in its lifetime is trapped by the first filter.
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,313
    Re: Oil Change
    Full flow oil filters were adopted to reduce the amount of cleanup required when motors are manufactured. I have disassembled new motors in the crate direct from the manufacturer for "blueprinting" and on the average found about 1/2 teaspoon of machining chips and foundary sand in the bottom of the oil pan. On startup all the oil goes through the filter so it is all trapped. In the good old days of bypass filters it all went through the bearings. The bypass filters did trap a lot finer stuff so the oil looked cleaner longer.
    C66 Racing's Avatar
    C66 Racing is offline Cadillac Owners Enthusiast
    Automobile(s): 06 CTS-V (sold)
    Oct 2006
    King George, VA
    680
    Re: Oil Change
    Quote Originally Posted by dkozloski View Post
    AMSOIL has a new line of full flow full synthetic media filters developed in conjunction with Donaldson and Wix that will help remove more of the wear products found in the motor:
    AMSOIL Ea Oil Filter
  9. Remove Advertisements
