Results 1 to 10 of 10
Thread: is this normal or could this be my problem
    OffThaHorseCEO is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 ATS Premium 3.6, 1989 Allanté
    Jul 2005
    Fayetteville NC
    33
    4,513
    theres a rubber boot between the throttle body and the intake manifold
    when i open my hood and run my engine, after the idle rpms drop, i can hear a hissing sound, i used a piece of hose and stuck one end to my ear, the other end searched the area for the sound
    turns out its on the throttle body side of that rubber boot, all along the edge but mainly in one spot, is that normal or is that whats causing my cadillac to run like shit, shudder like a 5 yr old in a haunted house on halloween, and thrw codes
    codewize's Avatar
    codewize is offline Cadillac Owners Master
    Automobile(s): 91 Brougham d'Elegance / 95 Fleetwood Broug/ 01 DTS / 11 CTS Lux
    Apr 2005
    Upstate NY
    50
    6,920
    Re: is this normal or could this be my problem
    If there's an air leak there I'm sure that will cause havoc.
    Ownership:
    91 Brougham d'Elegance 350
    95 Fleetwood Brougham
    01 Custom Deville DTS
    2011 CTS4 Luxury
    Memberships:
    National and regional Cadillac & LaSalle Club
    Proud Volunteer - Northstar Tuning Project
    Guinness World Records - Largest Cadillac Parade
    Jul 2005
    Fayetteville NC
    33
    4,513
    can you do me a favor, i know you have a deville same model year as mine, thing is, im not quite sure is a leak, would you mind checkin your car see if it hisses there? it may be the sound of somethin else, cause fuel lines pass thru there maybe thats what im hearing
  5. #4
    codewize's Avatar
    Apr 2005
    Upstate NY
    50
    6,920
    Is it like a rubber sleeve / connector type thing? Do you have the beauty cover off to get to it.
    Sure I'll check but I wouldn't expect it to sound like a hiss. I would expect more of a lower toned flow of air sound. High pitched hiss like a snake sound would indicate to me that air was passing through a pretty small hole.
    I will have a look tomorrow when I have a few minutes.
    Ownership:
    2011 CTS4 Luxury
    Memberships:
  6. #5
    69
    82,262
    What you are hearing is a vacuum leak. The rubber coupler has a crack in it. I have heard of this before. You can verify this by spraying some WD40, BraKleen or such around it. I'm sure you will hear an RPM fluctuation. The coupler needs to be replaced.
  7. #6
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,282
    A very good temporary repair on torn rubber parts can be made by cleaning them with dish soap and hot water then carefully gluing with super glue. You can even use this technique to make your own odd size O-rings. Various liquids attack the glue but the repair will often last until you can locate an exact replacement.
  8. #7
    Submariner409's Avatar
    Submariner409 is online now If it won't run, chrome it
    Feb 2006
    MD Eastern Shore, Kent Island
    56,796
    Ran into the same symptoms on my '02 STS after changing the air filter. There's an air resonator box tapped into a 3" fitting in the intake hose after the MAF, held on by a circle clamp and rubber grommeted tang. I didn't check the connection when putting the whole mess back together, and the resonator was cocked in the fitting. The resulting air leak did exactly as you describe. Apparently, even the smallest vacuum leak can cause all sorts of problems in a MAF-controlled setup.
  9. #8
    Jul 2005
    Fayetteville NC
    33
    4,513
    ok guys thats for all the replies, yes codewise the beauty cover is off until i can fix the problem, or get it fixed, if i dont have the issue solved by pay day its going to a mechanic on payday
    is the 99 northstar set up the same way, i can easily locate a temporary replacement off of that year northstar if the setup is the same
    also is that a possible cause of the engine shuddering so much
  10. #9
    codewize's Avatar
    Apr 2005
    Upstate NY
    50
    6,920
    If there's a leak there, yes it will drive things crazy. Especially on a car equipped with a MAF sensor.
    Did you still want me to listen to mine? I kinda backed off that because of all the good replies.
    Ownership:
    2011 CTS4 Luxury
    Memberships:
  11. #10
    Jul 2005
    Fayetteville NC
    33
    4,513
    nah its cool, i kinda meant that at anyone with a 2000+ deville, but it seems the general opinion is that mine is bad but thanks anyways
  • You may not post replies
