Complete engine overhaul, need help ASAP
Results 1 to 7 of 7
Northstar Engines and System Technical Discussion Discussion, Complete engine overhaul, need help ASAP in Cadillac Engine Discussion; I am dedicating my weekend to bringing my 97 Deville back to perfect running shape. I want to change the ...
    Wicho is offline Cadillac Owners Fanatic
    Jan 2004
    Miami, Florida
    134
    I am dedicating my weekend to bringing my 97 Deville back to perfect running shape. I want to change the oil, oil filter, plugs, plug wires air filter. As far as the oil, oil filter and air filter, I know what to get. For the plugs and wires, this is the first time I have ever changed them on my own. What should I buy ? Should I check and re-gap the plugs before I put them in ? Any help would be greatly appriciated.
    99Classillac's Avatar
    99Classillac is offline Cadillac Owners Enthusiast
    Automobile(s): Ex-99 Deville owner, Now-04 DTS and 05 DTS. ZX6R Pilot too.
    Nov 2005
    Upper Marlboro, MD
    34
    841
    Re: Complete engine overhaul, need help ASAP
    Get AC Delco. I'm just trying to beat everyone else in sayin that. It's true though.
    Jan 2004
    Miami, Florida
    134
    Before I go ahead I have another question. I bought my car with roughly 85-89k miles on it. I switched the plugs at the time, but not the wires. Should I change them again with 195k on the clock ? How would I know the wires are still operating to par ? Thanks
    Jan 2004
    Miami, Florida
    134
    I was also wondering if I should change all the fuses under the hood ? I want to change them out before they go. Good....bad idea ? Thanks
    chazglenn3's Avatar
    chazglenn3 is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 White Diamond STS N* 1SF RWD ACC/HUD
    Sep 2004
    Tacoma, WA
    54
    1,959
    I don't think there is a need to change fuses...as far as I know the only reason for them to go bad is too much current running through them...not old age.
    dp102288's Avatar
    dp102288 is offline Cadillac Owners Connoisseur
    Apr 2006
    North Brunswick, NJ
    28
    4,236
    Wicho, I say change the wires and plugs. Another 100k miles have passed, and that's usually the interval to change them.
    69
    82,262
    Always check the plug gaps before installing them. Usually I would say, "if it ain't broke, don't fix it", but at 10 years old with almost 200K it is probably due for wires. Stick with A/C Delco. They obviously has proven to be reliable.
  10. Remove Advertisements
