Seville ECM Codes
Results 1 to 4 of 4
Northstar Engines and System Technical Discussion Discussion, Seville ECM Codes in Cadillac Engine Discussion; I have tried the searches and either I am not searching correctly or there just isn't a thread in to ...
    thebigone is offline Cadillac Owners Member
    Mar 2004
    5
    Seville ECM Codes
    I have tried the searches and either I am not searching correctly or there just isn't a thread in to this subject in particular. Which I find hard to believe.
    I have a recently purchased 1986 Seville. I have the following codes:
    B120, B121, B127, B336, B448, B552.
    I have searched and searched. Without having to buy a book could someone here help.
    Thanks,
    thebigone
    BeelzeBob's Avatar
    Dec 2002
    Fort Lauderdale, Florida
    52
    9,577
    Re: Seville ECM Codes
    Quote Originally Posted by thebigone
    Thanks,
    thebigone
    B120...twilight sentinel delay pot problem
    B121...twilight sentinel enable circuit problem
    B127...PRNDL sensor/switch circuit problem
    B336...loss of IPC data
    B448...very low refrigerant condition
    B552...BCM keep alive memory reset (battery disconnect..??)
    Mar 2004
    5
    What is the "IPC data" or "IPC?" Is it a sensor? or part of the PROM programming? Thanks for your help bob!
    Quote Originally Posted by bbob
    BeelzeBob's Avatar
    Dec 2002
    52
    9,577
    In your car that is the Instrument Panel Cluster... there is a micorprocessor in the IPC that talks to the rest of the system and the car (to the Body Computer, the Engine computer, etc...) The IPC receives infor to put up on the displays including the onboard diagnostics info. The code just means that at some point the IPC lost data coming in. It may be a temporary glitch, a battery disconnect, an ignition switch that is starting to wear and causing the timing of the contacts to change as you turn the key on and off, etc...
  7. Remove Advertisements
