Which kind of FPR?
Results 1 to 6 of 6
Northstar Engines and System Technical Discussion Discussion, Which kind of FPR? in Cadillac Engine Discussion; I have a 1999 ETC and the nylon fuel rail was leaking, so I ordered a stainless steel fuel rail. ...
    jlarson69 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Oct 2006
    19
    Which kind of FPR?
    I have a 1999 ETC and the nylon fuel rail was leaking, so I ordered a stainless steel fuel rail. I also noticed there was two part numbers for the fuel pressure regulator, one for the nylon and one for the stainless rail.
    Can I use my old FPR on my new stainless rail?
    fpmesiIII's Avatar
    fpmesiIII is offline Cadillac Owners Fanatic
    Automobile(s): 1996 Cadillac Seville STS (167k)
    May 2005
    Western NY
    473
    Re: Which kind of FPR?
    When ordering a new FPR for my '96 caddy, I remember seeing the option for stainless steel fuel rail or original nylon fuel rail. So you might want to get the FPR that is recommended for the stainless steel fuel rail.
    Rockauto.com has
    the AC-Delco nylon fuel rail FPR for $37.79 (part # 2171598) and the stainless steel fuel rail FPR for $41.79 (part # 2171630).
    Feb 2004
    FL
    2,250
    The old FPR will work in the new fuel rail. Just transfer everything over.
    I think the different part numbers are because of the different locking clips that each use, that are included. Not positive though.
    jholland is offline Cadillac Owners Member
    Automobile(s): '97 Seville '76 Eldorado
    Apr 2005
    67
    Cadillac replaced my fuel rail under a recall at no charge. Have the dealer run your VIN.
    68
    81,891
    Quote Originally Posted by jholland View Post
    The recall was for '95 -'97 only.
    Feb 2004
    FL
    2,250
    guess it's about time for them to extend it, now that 98's are old enough to start leaking...
  9. Remove Advertisements
