97 deville-changing plugs and wires
Results 1 to 7 of 7
Northstar Engines and System Technical Discussion Discussion, 97 deville-changing plugs and wires in Cadillac Engine Discussion; i've taken the distributor plate off of the valve cover.........now can i remove all of the sensors, to be able ...
    jameswinburn is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Oct 2006
    37
    i've taken the distributor plate off of the valve cover.........now can i remove all of the sensors, to be able to move distributor farther out of the way for easier access to rear plugs and wires........suggestions please.....
    68
    81,887
    Re: 97 deville-changing plugs and wires
    If you mean the coil pack, yes. Remove 4 mounting bolts, then 4 electrical connectors (2 on each side). Then just move the coil pack out of the way.
    Oct 2006
    37
    thanks for info......i have finished this task and car is running great....however the check engine light is still on..........how do i clear it? info will be appreciated..........jim.
    68
    81,887
    What DTC's are you getting? Clearing them may not help. If they are current they'll just return.
    Oct 2006
    37
    pcm0300, pcm0603, u1096, u1064,irc b1771, irc u1096, irc u1064, all in history and acm b1312 current.........
    68
    81,887
    You'll find the DTC definitions here.
    http://myweb.accessus.net/~090/dtcobd2.html
    After the DTC's have been displayed, use the HIGH FAN button to answer YES to the prompts and the LOW FAN button to answer no til you get to CLEAR CODES?
    1998Deville's Avatar
    1998Deville is offline Cadillac Owners Fanatic
    Automobile(s): 1998 Deville D'Elegance
    Nov 2005
    Sunny Florida
    41
    133
    Here are the 'descriptions' for the codes (up to you to figure out why they are happening)
    P0300 - Engine Misfire Detected
    P0603 - Control Module Long Term Memory Reset
    U1096 - Loss of Communications with IPC
    U1064 - Loss of Communications with DIM
    B1771 - Cassette tape slow
    B1312 - High Side Temp Sensor Open Circuit
    If it were me, I'd clear all the codes for all the modules and then shut the car off and restart and check codes again. History mean just that, they happend in a prior driving cycle. Current means the fault is currently present. Almost looks like someone had disconnected some wiring with the battery still connected but then plugged it back in? With the Two network codes (U1096 & U1064) Loss of comm with IPC (Instument Panel Cluster) and DIM (Dash Intergration Module), not sure about the B1771 (Never used my tape player, just listen to CDs or the radio), the B1312 has something to do with the AC system, the P0603 means the battery went dead or was disconnected and P0300 could be as simple as previously having bad gas (in the tank not from food ) Hope this is a little help, I'm far from an expert!
  10. Remove Advertisements
